catalytic converter
Old Apr 5, 2008 | 02:55 PM
bryanbuck's Avatar
5th Gear
catalytic converter
I need to replace my CC but was wondering if I can just permenatley remove it. If I don't replace it will my engine light remain on?
Thanks.
Old Apr 5, 2008 | 04:50 PM
ChrisQ1980's Avatar
hates the winter
Yes, you can remove it and use a test-pipe, or replace it with a Random Tech High flow cat. If you delete it, you will get a CEL unless you "trick" it using the spark plug de-fouler method.
My suggestion is to get the random tech high flow, so you can remain legal and still get better performance.
Old Apr 5, 2008 | 06:12 PM
Rajca's Avatar
wham bam thank you ma'am
or u could put one of those o2sensor caps which will limit how much exhaust hits the sensor and it wont turn on the light. had a buddy so it to his s10 and and check engine light
Old Apr 5, 2008 | 06:27 PM
asujosh1's Avatar
Punctuation Nazi
Most shops will not remove the CC from a car since it is a Federal law to have the Cats installed on your car. If you have inspections in your state you could be looking at some trouble.
Old Apr 6, 2008 | 01:06 AM
02type-s's Avatar
-Arsenic-
Just get the Random Technoloy cat
Old Apr 7, 2008 | 02:27 PM
bryanbuck's Avatar
5th Gear
Thanks for the info. Since I am in SC I don't have inspections so I will try the spark plug method. Where do I find the O2 sensor on my '99 TL 3.2?
Aug 15, 2019 12:58 PM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Rcelestino93
Sep 23, 2015 10:01 PM
jpm3071
NY/NJ
Sep 7, 2015 08:25 AM
