Carrier Bearing needs replacement?
Old May 15, 2014 | 02:35 PM
TimSallinger's Avatar
Hi, hoping there's someone out there with some insight on this.
'01 TL w/ the 5AT.
I've been getting this weird thrumming noise while moving that gets louder the faster I go.
Mechanic says I need a new "carrier bearing" -- and that it's a part that was only ever used in a handful of cars and was discontinued five years ago.
He wants $200 to replace it, including labor.
Does that sound right? Am I getting ripped off?
Thanks.
Old May 15, 2014 | 02:38 PM
wheel bearings?
i wouldnt have him work on it unless he is POSITIVE.
it doesnt sound like he is POSITIVE on the diagnosis, as he sounds like his throwing parts at the problem on your dime.
Old May 15, 2014 | 03:03 PM
fsttyms1's Avatar
Id find a new mechanic, or have him tell you exactly what is wrong. There is either a wheel bearing or the intermediate shaft bearing. Neither of which were only used in a hand full of cars nor discontinued.
Old May 15, 2014 | 04:02 PM
Skirmich's Avatar
Your "Mechanic" doesn't have a single clue.. Get a new mechanic or shop.
Old May 15, 2014 | 04:48 PM
TLer trash's Avatar
I'll play the devil's advocate. It sounds like your mechanic is using a term that's been around a while. It's also called a midship bearing. He didn't indicate that it might be the bearing, he said it IS the bearing. In response to fstty, he did tell him exactly what is wrong, he just used old school terminology. While I wouldn't say they were used on a handful of cars, I see way more cars that don't use that setup than do. I sure wouldn't change mechanics over a terminology issue. Get a second opinion if you have doubts, but make whoever you choose understand that if their diagnosis and repair doesn't fix it, it will be free. This is a reasonable demand, as isolating a center bearing from a wheel bearing is pretty straight forward. Caveat: I've been an ase certified master mechanic for over 40 years, and may have called it a carrier bearing, even on a front wheel drive car on occasion.
Old May 15, 2014 | 09:25 PM
Thanks to all for the input so far. I will say that before my mechanic even looked at it, he mentioned it might be a wheel bearing. Evidently after inspection he decided it was not. Regardless, you've given me enough doubt that I will definitely go seek a second opinion before getting this done.
Old May 16, 2014 | 06:56 AM
fsttyms1's Avatar
Problem is is if he is going to say whats wrong he needs to use the correct terminology. If we were dealing with a rwd 2 piece driveshaft calling it would make sense as that is what it would be called. On a fwd like ours that bearing isnt considered a mid midship or carrier, its called an intermediate shaft. If it is infact the intermediate shaft/carrier bearing its still not a hard replacement or a hard one to get. 200 in labor with the part isnt a bad price, but i would make sure that is the problem. I havent seen too many of them fail.
2012wagon
Sep 29, 2015 04:21 PM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
Sep 14, 2015 10:09 PM
heyitsvic
Sep 4, 2015 09:38 AM
