car paint
Old Nov 1, 2013 | 11:00 AM
Zane1111's Avatar
car paint
i have an acura tl-p 2001 and the paint is rubbish pealing gold and basicly the worst paint on a car that runs so great. i had plasti diped the whole car but it seams that's not a good permanent solution because its been 6 months and it already seems to be coming off :/. i have about 1 grand to spend on paint i live in dallas tx does any one know were i can get a good paint job for around 1k and does any one know if maacos any good because i got mixed reviews on them.
Old Nov 1, 2013 | 12:13 PM
Nicks2001tl's Avatar
Keep in mind a thousand dollars will buy you a thousand dollar paint job.
Shop around read some reviews and see what you can find out.
Old Nov 1, 2013 | 07:06 PM
Tosh's Avatar
Eurotrash
from their website:
"Plasti Dip is a multi-purpose, air dry, specialty rubber coating. It can be easily applied by dipping, brushing, or spraying. Plasti Dip protective coating is ideal for a broad array of do-it-yourself projects around the home, garage, garden, and elsewhere. It protects coated items against moisture, acids, abrasion, corrosion, and skidding/slipping, and provides a comfortable, controlled grip. Plasti Dip remains flexible and stretchy over time, and will not crack or become brittle in extreme weather conditions. It has been tested and proven in temperatures from -30°F to 200°F."
So what do you mean when you say "the whole car"?
Old Nov 2, 2013 | 12:39 PM
fsttyms1's Avatar
If you preped the car properly and put enough coats on it should last you years
Old Nov 2, 2013 | 12:40 PM
fsttyms1's Avatar
I would take that as "The WHOLE Car" was sprayed with plastidip.
Old Nov 2, 2013 | 04:38 PM
3.2TLc's Avatar
Lot's of Plastidip, hmm....maybe skimped a bit on prep or application ???
Old Nov 5, 2013 | 07:50 AM
fsttyms1's Avatar
Probably done with a rattle can and not enough coats to make it thick enough to last.
Go to dipyourcar.com and buy a kit with the dip. It comes with the sprayer and plastidip for a very reasonable price
Old Nov 5, 2013 | 02:11 PM
MrChanh's Avatar
does anyone know about how much a "wrap" would be?
nanos
Nov 12, 2015 08:41 PM
merc009
Oct 3, 2015 12:59 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
TheWrench116
Aug 30, 2015 06:19 PM
