car loosing power
Old Jan 20, 2017 | 07:07 AM
andrews34's Avatar
car loosing power
At between 32-3500 rpm engine looses power slow exceleration is fine even 80mph even in park engine 3500 rpm engine looses power.Changed plugs no effect. New front motor mount no change what should I try next ? 2001 tl 200,000 miles has always run great for 16 years.
Old Jan 20, 2017 | 07:44 AM
alexb92's Avatar
Wrong forum, this is for the 3G TL (2004-2008).
Old Jan 20, 2017 | 07:52 AM
Moved to proper sub-forum.
Hope you get the help you need
Old Jan 20, 2017 | 08:02 AM
Majofo's Avatar
no vtakkkk
Old Jan 20, 2017 | 09:03 AM
Sounds like a vacuum leak of sorts..
Old Jan 20, 2017 | 01:07 PM
MikeND's Avatar
Sea Foam Motor Treatment
You could run a can of Sea Foam motor treatment through the fuel system from the gas tank to clean the fuel system. It does not necessarily explain why you are having a loss of power in a very specific rpm range, but it couldn't hurt and is inexpensive. Here is a link to Amazon that is selling it for $6.97 - Sea Foam SF-16 Motor Treatment - 16 oz. https://www.amazon.com/dp/B0002JN2EU..._b5LGybK7W2CFT
Old Jan 23, 2017 | 07:15 PM
smcafee's Avatar
While Seafoam may have some benefit, your symptoms point to other causes (and solutions).
Chaotik
4G TL Problems & Fixes
Mar 21, 2017 10:20 PM
Dejan13
Oct 14, 2016 09:58 PM
RDXMac
Oct 12, 2016 02:17 AM
Skirmich
1/2G MDX (2001-2013)
Oct 10, 2016 05:45 PM
kevin963
Oct 6, 2016 08:34 AM
