Car / Electrical Dead
Old Apr 8, 2010 | 08:21 AM
I am currently on the road on a business trip and went out to my car this morning to find out that it won't start or even attempt to turn over.
Nothing that requires any power is working and I am hearing a clicking / buzzing sound that seems somewhat cyclical coming from the area to the left of the steering wheel where the fuse panel is located.
Does anyone know if this is a common issue / easy fix or should I just go ahead and call the Acura dealership here?
Old Apr 8, 2010 | 11:46 AM
TLer trash's Avatar
My first guess would be the battery; especially if it's the original. If it is original, you've made it a lot further than most. This is the 03 isn't it?
Old Apr 8, 2010 | 12:32 PM
It is an 03, but has already had the battery replaced. A simple jump seems to have taken care of the problem, but I guess I will see.
Old Apr 8, 2010 | 02:17 PM
NSXNEXT's Avatar
Check the battery terminals are on the battery tight as well as all of the grounding wires.
Old Apr 8, 2010 | 02:18 PM
NSXNEXT's Avatar
And obviously make sure you don't leave any interior lights on when you park.
Old Apr 8, 2010 | 02:28 PM
totaledTL's Avatar
Originally Posted by TL2000
...A simple jump seems to have taken care of the problem, but I guess I will see.
It will be back.
Old Apr 8, 2010 | 02:45 PM
fsttyms1's Avatar
Sounds like a battery issue. Like said above make sure your battery connections are tight and corrosion free. Also have your battery load tested.
Feb 25, 2020 09:57 AM
lland
Oct 4, 2015 04:47 PM
tealt
Sep 1, 2015 09:03 AM
Aug 30, 2015 02:39 PM
