Can someone help? Brake line is leaking and pedal presses down almost all teh way!
Subscribe
Apr 22, 2013 | 09:31 PM
I have a 99 TL and one of the lines right at the *ABS module* above the right tire (i think thats what its called) is constantly leaking, it has been tightened completely but still leaks. And the brakes are working a lot less effectively, pedal presses down twice as far as before! any idea's what needs to be done exactly and how much this will cost me?? Thanks.
Reply 0
Apr 23, 2013 | 07:21 AM
the obvious answer would be to replace the line that is leaking, then bleed the brakes.
Reply 0
Apr 23, 2013 | 07:24 AM
Apparently the fitting is possibly stripped or worn and needs to be replaced.
Reply 0
Apr 23, 2013 | 07:59 AM
and hope the threads & hole on the ABS unit itself are OK.
Reply 0
Apr 23, 2013 | 10:34 AM
It seemed very tight to be begin w/ i'm not sure why this happened.
Reply 0
Apr 23, 2013 | 10:38 AM
^pictures are worth a thousand words.
Reply 0
Apr 23, 2013 | 10:43 PM
Right at the seal point (or some point there) of top left line is leaking very bad even after tightening it! Thnaks.
Reply 0
Apr 24, 2013 | 06:59 AM
so, it needs to be replaced.
Reply 0
Apr 25, 2013 | 07:50 AM
First thing to do is STOP driving the car. Its very dangerous having a leaking brake line with reduced braking. Bring it to a brake shop and have them see if it needs a new line/fitting and rebleed the brakes.
Reply 1
Apr 25, 2013 | 05:16 PM
Yeah, ya never want to compromise your car's effective braking power......as it could end up being a factor in jeopardizing someone's life at the wrong time and place.
Reply 0
Subscribe
