caliper piston bad?
Old Apr 16, 2006 | 08:28 PM
payyourtoll's Avatar
caliper piston bad?
changed the front pads today, and noticed that the driver side boot around the piston is shot. I am assuming that the caliper will eventually fail due to this?
Old Apr 16, 2006 | 09:19 PM
fsttyms1's Avatar
Yes, it will allow debris in and ruin the seals.. Mght want to look into getting that repaired/replaced.
Old Apr 16, 2006 | 09:37 PM
I didn't know I could repair or replace it, I thought I would need to replace the entire caliper assembly
Old Apr 17, 2006 | 09:35 AM
snowman81's Avatar
Sippy Cup (x2)
I don't think that you can buy caliper components seprately but I've only looked on acuraautomotiveparts.org. You might check some other places though. One question I would have is can you replace only one caliper or do you have to replace both if one is bad? Just wondering if it's the same as pads or not.
Old Apr 17, 2006 | 12:34 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
you can replace just one as long as it's like for like. it shouldn't be an issue. if you upgrade then yes, replace both.
when my friend's legend needed a new caliper we found the rebuild kits at autozone (special order though). you may want to call them and check. otherwise you can probably find a caliper on ebay or some online store somewhere.
SSTS
SidhuSaaB
May 30, 2020 12:40 AM
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
