CAI Sucks
Old Jan 4, 2010 | 02:09 AM
rk5tar's Avatar
CAI Sucks
My intake been sucking air by itself why its in neutral as if i was lightly stepping on it. does anybody know what the problem is cause it never did that before?
Old Jan 4, 2010 | 02:17 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
If you are talking about that "hiss" of air, it's supposed to sound like that. Maybe you never noticed it before?
Old Jan 4, 2010 | 04:30 AM
Rajca's Avatar
wham bam thank you ma'am
like the rpm keeps jumping up and down? vacuum leak, dirty/bad iacv
Old Jan 4, 2010 | 08:25 AM
fsttyms1's Avatar
can you be a little more specific?
Old Jan 4, 2010 | 02:02 PM
jjashaa's Avatar
Avant Garde Wheels
Is your idle at 700-1000~~ rpm???
At idle it should suck in some air so u should hear a bit of it at a stop.... (I don't remember what a CAI sounds like at idle )
But if it's really loud, check hoses and tb cables....
Old Jan 4, 2010 | 02:17 PM
TequiLa's Avatar
(ಠДಠ)
does it sound like this (the begginging of the video)? http://www.youtube.com/watch?v=0jcn4Qd5Mcw
Old Jan 4, 2010 | 02:24 PM
JterrorC's Avatar
Always a Honda =Þ
that hiss gets annoyin after a while....specially when my cars cold n its around the 1200....(is that bad by any chance?)
Old Jan 4, 2010 | 02:41 PM
Mista Juice's Avatar
do you have the ac/heater on?.. mine gets louder off and on at idle when the fans or whatever kick on..
Old Jan 4, 2010 | 02:45 PM
xtremex626's Avatar
Regional Coordinator (SoCal)
Probably a leak. Retighten the clamps that came with your CAI. Or you can spray blake cleaner where the intake connects to the throttle body (if the brake cleaner gets sucked in, you will know you have a leak cause the engine will kinda stutter). You can also do this to where your intake and air filter meet. Good luck!
Old Jan 4, 2010 | 11:31 PM
rk5tar's Avatar
no its idle between 700 and 1000rpm. but when i lift the hood and listen to the intake it sucks air as if i keep tapping the gas pedal lightly every 2-3 seconds or so. im starting to think its a leak too but dnt really know how to fix it.
Old Jan 5, 2010 | 04:20 AM
Rajca's Avatar
well. first find the leak, touch and move every hose around the intake, and make sure the clamps are on tight.
Old Jan 5, 2010 | 08:10 AM
fsttyms1's Avatar
An easier way is to spray some carb cleaner around the fittings. If the idle changes you found your leak.
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
Sunnyj209
ILX
Sep 30, 2015 09:31 AM
h22lude
Sep 27, 2015 06:22 PM
