Buzzing sound
Old Apr 9, 2017 | 04:23 PM
TypeSport's Avatar
9th Gear
Buzzing sound
When I start my car, a buzzing/vibrating noise comes from what seems like the audio deck but the noise occurs even when I turn the stereo off. The sound lasts for about 10 seconds then takes a short break then happens again for about 3 seconds then it goes away until I start the car again. Any ideas on what it could be??
Old Apr 10, 2017 | 09:41 AM
frankjnjr's Avatar
sounds like what you are describing (may) be the ABS self-check system. does one of the two noises sound like a "groaning" noise. the ABS self-check related noises, two on my 2003 type s, only occur each time the car is started and driven a short distance. one noise, a very pronounced "groan" is very obvious and quite disturbing until you realize it is related to the ABS system and quite normal. does the noise you are experiencing occur after the car is started, but before the car is driven a short distance, or while the car is idling in park, neutral or drive and not actually being driven?
Old Apr 10, 2017 | 09:48 AM
TypeSport's Avatar
9th Gear
The noise starts right when the battery is turned on. It doesn't affect it if the car is driving or not. It just recently started happening and I've had the car for about 4 months.
Old Apr 10, 2017 | 09:56 AM
can you record it please?
Old Apr 12, 2017 | 07:03 AM
TypeSport's Avatar
9th Gear
Yes I will record it but I'm almost positive it part of the cassette player now.
bigcocoon
Apr 17, 2017 03:18 PM
