Brakes...dont know what to do
I have a 02 TL-P and this past march or april i got brembo rotors and hawk hps brake pads installed in my car however my brakes are not working like they should be....i can have my parking brake on and still drive my car...that is how weak the brakes are ....does anyone know what else my needed to be done to fix this cause i have a hard time braking...................
PLZ HELP........
PLZ HELP........
PLZ HELP........
PLZ HELP........
Your parking brake and standard brakes are two completely different things. Which one is the problem? Or is it both? Snowman's right about the standard brakes. If you press on the pedal and they feel spongy, then it's most likely air in the lines or maybe low hydraulic fluid.
If your stomping on the brakes and the pedal doesn't go to the floorboards, but you still don't stop, then there is a problem with the brakes themselves.
If your just taking about the parking brake, then you can adjust that (as Snowman says) under the center console or at the rear wheels. You'll have to take off the rear wheels and get to the rotor, or better yet, take the rotor off, but you can do it. Or,.. you could probably have someone do it for about $30.
