Brake lights dont work
Help guys, on my 03tls i have the window brake light the wing/trunk brake light and the standard brake lights on the body, my brake lamp warning light on the dash came on the other day and taught i had a burnt bulb, when i check all four bulbs in the tail lights were on, but when applying brakes none of the tails lights show the brightness when the brake is applied, only the window and the wing/trunk lights shows brakes is applied, any suggestions, thanks in advance
2k3BLUTLS (02-08-2012)
I agree, remove the suspect bulbs for inspection--or buy the 2 pack of them for 6 bucks at parts stores
I had 1 brake bulb go out- the other followed soon after,,
odd how they get the same wear~
Thanks guys after spending hours today going thru all fuses, checking the brake light switch, and other possible suspects, found out there is a brake stop sensor located behind of the driver tail lights, removed the tail light from body, whit box with bout 6 wires, coming out of it, unplugged it and found the green wire going to the bulbs with corrosion, gave it a clean and all brake lights worked, also replaced all bulbs hopefully they can be on the same life pattern now
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
drewdeezy03
09-03-2015 08:04 PM
