Brake lamp????
Old Apr 1, 2006 | 07:05 PM
Hitlayers's Avatar
Brake lamp????
What's up peoples???? Finally today did the 02 light conversion on my 99, sweet deal, when I was done I started up the car pressed the brakes and my "Brake Lamp" light came on so I figured I hit one of the bulbs and blew it out, so I got someone to look at the back so when I press the lights he could tell me which one was out, come to find out neither one was out.........What else could it be causing this light to come on????????????
Old Apr 1, 2006 | 10:58 PM
TunedTL's Avatar
Initial D
did you check the 3rd brake light
Old Apr 2, 2006 | 10:49 AM
Hitlayers's Avatar
The one on the top by the rear window???? No I didn't, going to check now.
Old Apr 2, 2006 | 10:06 PM
Hitlayers's Avatar
I have checked all of my lights, they are all on, what else could be causing my brake lamp light to be on??????
Old Apr 2, 2006 | 11:30 PM
GaryBear's Avatar
Mabe the LED's don't draw as much current as the incandescent bulbs did, so the brake lamp circuit thinks there is now an open circuit (like a bulb burned out), lighting the brake indicator lamp. Could be u need another resistor to ground in the ciruit so it would draw a little more current. Just a thought
Old Apr 3, 2006 | 08:09 AM
Hitlayers's Avatar
I didn't change the bulbs I changed the housing from the 99 tails to the 02 tails, thanks for the input but that can't be the case.
Old Apr 3, 2006 | 02:25 PM
demolition_x's Avatar
Agean Blue Bishes
did you check with the lights on then with the brakes applied. the bulbs are dual filament so when one filament blows it will trip the lamp indicator.
Old Apr 3, 2006 | 02:36 PM
Hitlayers's Avatar
Ummmmmmmmmm, interesting, will do tonight, thanx
Old Apr 10, 2006 | 09:52 AM
Hitlayers's Avatar
OK, found the brake light that was out, replaced it, light went off, but when I turned the car off and turned it on again and pressed the brakes it came on again then it went off again this is annoying, do I have to reset something to get this light off completely???????
Old Apr 28, 2006 | 06:00 PM
NrKissed's Avatar
'02 TL Type S
I am having a similar issue. I had not thought to check the lights while breaking though. Guess I will check tonight.
Old Apr 28, 2006 | 06:09 PM
Delirium's Avatar
Pretty sure its the prob got the same issue here .
Old Apr 29, 2006 | 08:39 AM
Hitlayers's Avatar
Problem fixed, thanks guys..........It was a couple of bulbs burned out not just one as I suspected.......
Old Feb 29, 2008 | 04:24 PM
Precision Crafted's Avatar
How do you replace the 3rd brake light bulbs and where did you get the LED's?
GWEEDOspeedo
Jan 15, 2016 10:39 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
