bottomed out..
bottomed out..
i speed up to pass som slo fuck on the street as soon as i cut to the left theres a huge dip on the ground...couldnt see it from where i was tailgatin...the car feels likes its flying at first..and as soon as the cip comes back up the car decides its time to go down....horrible bang...i pulled over to check what i fucked up..but couldnt see anytin....that was last nite...today i put the car in reverse here som cans scrapping the flr..in drive norm... realize my oil light is on..i figure yea im due for maintenance in a bit lemme check how the dip stick look...dip is clean as a whistle................ as if it had no oil for weeks...
...damn the impact was more on the rite side...oil pan mayb?..i see all my oil on the spot i park it last nite...i cant see under the car..
1st thing first. DO NOT DRIVE THE CAR.
Jack the car up and see what's going on. Sounds like you cracked the oil pan and quite possibly the transmission case.
i think everytin leaked out..flr is all rainbowy...i opened up the cap and i see everytin was still lubed...but that reverse noise was killin me...
rite now the sidewalks are flooded from rain..iknow theres a place in the front i can jack the car up...where do i position the circle stand thing... so i can hav a clearance...i hav the 5 quarts here..should i put it in n drive to my mechanic about 6 miles out ..highway about 5 min...and streets another 5 min...
...damn the impact was more on the rite side...oil pan mayb?..i see all my oil on the spot i park it last nite...i cant see under the car..tranny....damn i hate talkin bout that...
h&r sport n gyb gr2
h&r sport n gyb gr2
DO NOT DRIVE THE CAR! You may have already damaged things and you dont want to do more.
Put in some oil and see where it leaks out from. Also check your trans fluid and see if thats low. IF..... and only IF you add all 5 quarts and it doesnt leak out would i even attempt to drive it to the mechanic.
ye man....i talk text n type like that...if you knew me you would understand...takes me forever to type the correct way... my apologies.... but only found one typo ... cip = dip
where can i put the jack??
before adding oil
didnt even see the crack from where i was...i just stuck the camera in there
after adding oil
then i stuck my head in and realized lucky charms do nothing for me
so should i get a new pan...or epoxy this??
after adding oil
ye def not movng....the driver side has scratches on the frame but all old not fresh like the oil pans....
can i jus clean it up real good...epoxy that together?? in the meantime...acura said itll take a week or so til it comes in from cali.....lame...
not so much a pothole...but you know when they are reconsturcting somtin...the cut out the road to get to pipes...and then they patch it back up....yea well the patch (wider den our cars) sunk...ill take a pic of it when i get bac on the road...
if u really need the car. jb weld it, order new pan, then replace the old one when u get the new one. when u jb weld it, let it cure, pour oil, clean all the old oil and sludge off and check for leaks.
I would of just looked around for parts before buying them from Acura. There are only some maintenance parts that should be ordered through Acura. I'm sure you could of find that at a salvage yard or somewhere that sells used parts.
So you didn't see that crack yourself? You just happened to put the camera there accidentally and that is how you found it?
junkyards wont part out oil pans...then the engine wont sell...but i saw the crack after i pour the oil in and saw a cayon goin down i got real close through the fender well and saw it...but the first shots i had no clu i jus took shot of the oil...
