Bosch Spark Plugs VS NGK
Old Mar 28, 2013 | 05:14 PM
Shawn Lawrence's Avatar
So I have a sputter when I accelerate and maybe thought it was the EGR valve so I replaced that. Next I replaced the spark plugs after I went to Autozone and had her look up my car. They gave me Bosch Double Platinum spark plugs and I replaced my old ones but the problem still exist. I called the guy I bought the car from who also owns his own service shop and he told me Bosch plugs dont work in Acuras. Is this right? Please help!!!
Old Mar 28, 2013 | 05:15 PM
Karanx7's Avatar
Unregistered Member
Should use NGK only
Old Mar 28, 2013 | 05:41 PM
randomthought's Avatar
rebmeM deretsigeR
NGK iridium only. Did you clean the EGR passage ways and the intake manifold as well?
Old Mar 28, 2013 | 05:43 PM
Americandream's Avatar
Originally Posted by Karanx7
Should use NGK only
What he said!
Old Mar 28, 2013 | 06:07 PM
AcraAdi93's Avatar
NGK or Denso will be fine
Old Mar 28, 2013 | 09:56 PM
HairyMonkey019's Avatar
If you search through these forums... EVERYONE says NGK only.
Old Mar 28, 2013 | 09:57 PM
Dman00tl's Avatar
Use NGK
Old Mar 29, 2013 | 06:32 AM
Thanks everyone for the help!!
Old Mar 29, 2013 | 06:45 AM
3.2TLc's Avatar
Bosch vs: NGK plugs
Yeah, as everybody knows....NGK !!!!! are the best for our finicky TL's.
But, as Randomthought said....make sure that the passage ways and intake are cleaned properly. More than likely the real problem.
Check the vac and electrical connections. Run some fuel system cleaner through the gas tank to help clean the injectors.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
