Blower motor nightmare
Old Dec 28, 2016 | 09:11 PM
9thIslandTL's Avatar
So my hvac doesn't move air as strong as it should on all increments. Heater works fine and A/C blows cold, changed out the cabin air filter. Air/mix control switches as it should. I'm in the process of changing out the blower motor and resistor to new ones. Already got the new parts on hand, ready to go in. I go to work on the parts and was initally disgusted with what I found. Took off the old parts and proceeded to take these photos:
^Left is new, right is...well, you know...^
^...wow...^
^thick wires...is that right?^
Looks like I'll have to go to the junkyard to find a clip. Question here is, anyone know, based on where the wires are coming from the car, is - or + ? PIN diagram maybe? Are those even the right wire gauges to use?
Old Dec 28, 2016 | 10:02 PM
CurrentDraw's Avatar
Wow it looks like they've stuffed bunch of hondabond into the connector.
There was a TSB back in the day for the hvac blower motor connector melting due to excessive current. Whoever did that repair took it to another level
Luckily for you there is a hvac sub-harness available at your local dealer which will plug right into your new blower motor. They may no longer stock it but I'm sure you can special order it.
Old Dec 29, 2016 | 06:51 PM
Thanks, I'll look into that. I'm also gonna try the junkyard and see what else I can find.
Old Dec 29, 2016 | 07:18 PM
acurapartsdiscount's Avatar
Former Sponsor
https://www.acurapartsdiscount.com/o...or-04321s0ka00
this is what you need. if you find one at a wrecking yard more likely its going to be melted.
Old Dec 29, 2016 | 10:02 PM
01acls's Avatar
Yellow/Black is Blower Motor positive.
Blue/Red is Blower Motor to Power Transistor then ground.
Gauge of wires look fine (same gauge or a little larger).
Old Dec 29, 2016 | 10:44 PM
Nice, I'll be ordering from there shortly. Thanks!
Thanks, this helps a lot!
