Best ATF to keep trans in top shape?
Old Apr 18, 2011 | 11:49 PM
The Noodle's Avatar
I am very new to these Acuras and a day old with my 2002 with 210K miles on her. I want to change the trans fluid but Im not sure what the best process is and what to put in her.
Can someone recommend what I should do? SHould I just use Honda ATF? Or is there something that works better to keep my 3.2L going well?
thanks
Old Apr 19, 2011 | 01:03 AM
Karanx7's Avatar
Unregistered Member
Uhh, 210k? Don't touch the fluid unless you have a service history. If the fluid hasn't been changed in ~100k, then you might end up killing it with an ATF exchange. I wouldn't even try a 1x3.
Old Apr 19, 2011 | 11:43 AM
01tl4tl's Avatar
I would take a 3 ounce sample drain of the atf and send to blackstone labs for analysis
find out how old it is, and how many good or bad things are floating around inside the trans before messing with the fluid
please see the thread Tranny Failure Thread for details on our trans issues,,skip to last several pages
Old Apr 19, 2011 | 11:44 AM
01tl4tl's Avatar
look at the bolts thru the trans and attaching things to it- are they painted blue?
good, thats a warranty unit- at least its not 200 on it!
Old Apr 19, 2011 | 09:15 PM
sbuswell's Avatar
I need 2 more gears
if you have never changed the fluid and that is the original trans then you are one lucky guy and I would not even consider changing the fluid.
TypeS860
Jan 10, 2026 11:11 AM
quanaman
Jan 9, 2023 07:33 PM
IBankMouse
Jun 13, 2020 12:53 PM
jsonkimz
Mar 28, 2016 07:49 PM
LeVeL
Oct 18, 2015 04:19 PM
