another HID/Ballast thread! (opinions needed)
Old Jan 5, 2013 | 05:34 PM
schwag27's Avatar
6th Gear
ok - so i have a similar problem as many. Driver side lo-beam out (good bulbs, work on other side). Lens has a lot of condensation on it, but bulb has been out so not able to burn it off. i have read many threads about this but looking for a check list of how to go through the possible problems.
1) check bulb (bulb is good)
2) check fuse (driver side lo-beam - anyone know which fuse this is?)
3) replace ballast?
4) replace lens unit or re-seal?
5) some other wiring bugaboo?
does that sound reasonable on how to attack this thing? would you do the order differently?
Old Jan 5, 2013 | 10:51 PM
LiveFive's Avatar
Should be either a ballast or a fuse. Is it an aftermarket ballast or OEM?
Old Jan 8, 2013 | 05:49 PM
Lordiv's Avatar
I agree with LiveFive. Obviously fuse is cheapest and easiest to check. After that, it is most likely your ballast. I do know that the aftermarket ballasts have a lower failure rate then the orginal part. So it may be time to do an upgrade to aftermarket if you havent already.
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
BKSleeper
Oct 7, 2015 10:20 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
heyitsvic
Sep 4, 2015 09:38 AM
dlknight
Sep 3, 2015 07:54 PM
