Amateur in need of help
Hello. I have a 2002 acura tl. While trying to rig a new wiring connection (which I now knew is dumb) to test my blower motor, I touched the two wires together and heard a pop. Now my compressor wont kick on. Also my radio and clock reseted. I have since checked the fuses and they are good. But my compressor won't turn on. Any help would be greatly appreciated as it is hot as heck outside. Thank you.
Fuse
I forgot to mention that when I start the car with the a.c.on the compressor starts for about 2 seconds then dies. I checked the 40 amp fuse under the hood and the number 3 and 8 7.5s on the drivers side. All were good. Any other fuses in particular that I could check? Thank you.
Unregistered Member
