Air conditioning slowly goes away.
I have a 1999 TL. The AC starts off ok, then it slowly gets warmer until it is probably only about 78 degrees. I have replaced the low pressure switch and vacumed the system and recharged it. When I measure the pressure it bearly gets to 25PSI on the low pressure side. I have put the 22oz of 134a in it, so I don't believe it is a charge issue. I removed the cabin filters the other day and they were very dirty, but it isn't any better now. Does anyone have an idea what my issue might be?
Has it worked right at all since you did a vac and recharge?
how long ago was that? and why - what broke before that and how long did the system sit broken
Could be an issue in the filling procedure caused this- I always suspect the last work done on the car
do some basic testing--feel the temp between 2 hoses coming from firewall to ac - how much differance in temp --none or a little?
High pressure side reading?
25 is good on the low side- ambient temperature dependant
One of the cans had 2 oz oil in it? not, each of the cans had oil
Ac should blow ~40 degrees cooler than outside air, to a min of about 38-40 F measured at center vent in console
Keep car doors open while filling freon- so ac stays On working full time
and have small box fan blowing extra air into radiator while working
When its hot out its going to be less effective~ but losing its cold abilty while driving and then be good again the next day-thats got me stumped right now
Who is our ac guru?
Who is our ac guru?
if it was just low, it would not get cold then get warm- it would never get cold enough
when adding freon, the low side pressure reading will go down as it nears full- the acceptable area on my guage is 20-40 iirc
do NOT add more freon without knowing high side reading- you can literally blow up the compressor!
If label says 22 oz and you put that much in- STOP and find out where it stops circulating
Is the metal tube under evap core- pass side under dash- is that iced over?
and the condensation drain tube for the ac from pass side to outside=-that drain is clear
Who is our ac guru?
Who is our ac guru?
Ok, to start the summer it would work but stop working in stop and go traffic. I talked to someone who works on car AC and they said that it sounded like the low pressure switch. I changed that. Since then it has worked then slowly gotten hotter.
It is probably blowing low 50s when working well.
I used 134a from a can with oil in it, approx 18oz. Then I filled it from a can of straight 134A.
I cannot check the high side pressure, my guage is broken.
I am my own AC guy. My dad owns an industrial AC service company, so I know a little, since I grew up helping him.
I'm sort of thinking that it might be over charged. I was wondering if overcharging could cause the low side to be lower than it should be.
The tube is not freezing.
Condensation is draining.
B A N N E D
so how well does it work OP when you are cruising along the highway
btw OP
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
commercial ac background is not the same as car ac experience
Yes overfilling can take the pressure reading to low
Many parts stores will loan tools including ac guages
passenger side fan should be ON with ac compressor On
i was going to say that first also
, but yeah sounds like a lack of airflow especially sitting
btw OP
but it does not sound like you know too much about A/C, cause you should know it would need airflow over the condenser in order to work effectively
btw OP
Assume a lot??
I stated that I changed the filters because of air flow.
It has air flow and the fans are running.
I would be willing to take a test against you to see how little I know about AC. You are assuming that I didn't check to see if there was air flow so that means that I don't know what I'm doing?
Who says something stupid like that?
Do I need to tell you everything I have done? Sorry if I didn't feel the need to write a 6 page esay on what I have done so far.
And yes I know that commercial ac isn't the same, that is why I am looking for information from people who probably know more than I do.
But the basic of heat transfer and the process of compression and expansion are pretty much the same.
I've seen a few clutch coils fade away as they heat up. Still had power to the coil, but it wouldn't engage the clutch. I was able to get it to happen just by letting the ac run at idle for 10 minutes or so. Just to be clear, BOTH fans should come on whenever ac compressor is on.
B A N N E D
Assume a lot??
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Why don't you just stop posting on this thread?
I'm looking for help not some guy who assumes too much and makes comments about my intelligence.
If I forgot to say, I will say it not. The fan is working.
Guess what they use the same terms for a condensor and evaporator coil in a home ac also.
Since you obviously are here to cause problems, could you please just avoid anything that I post and I will do the same for you.
To everyone else, thanks for the help.
You should also read beyond the first line. I stated in that same post that the "FanS" are running. I assumed someone as brilliant as you would know where the fan"S" are.
I have enough issues with my car, I really don't need someone like you trying to help.
Question, does the suction pressure stay at 25 psi the whole time the compressor is running? When/if the low pressure switch cycles the compressor off does the suction pressure rise quickly? Assuming you have the correct amount of refrigerant installed, I would say it sounds like a partially stuck TXV. I have had that experience myself on a couple of cars.
Once you evacuate the system you cannot draw it back in with the compressor running and feeding the freon through the low side of the system. So stick with home A/C and take your car to a professional that knows what the hell they are doing because you don't have a clue how an automotive A/C system works. I've learned enough watching and doing A/C work for my Dad at his shop to know your in left field.
B A N N E D
so in otherwords your just guessing on how much freon and oil is in the the system since your just opening and closing a can and did not measure the proper amount oil or freon nor did you heat up the freon and forced it in either like it has to be done.
I believe this is the problem. Do you know where I can find any information on changing it?
No you are not alone. Just another ass who assumes to much.
I have a digital scale and I measured in the remaining 4 oz, so I have exactly 22 oz, which is in the range on the label on the car.
I love you know it alls. Who can take a statement on a message board and go wild on what I did and didn't do.
By the way. I have a masters degree from GA Tech. I would be glad to talk engineering or CS with you anytime. Since you're so smart try reading between the lines there.
And as always thanks to those who actually tried to help me. I wish there was a way to get rid of those who only want to assume they know exactly what I did and didn't do.
By the way, you cannot start the compressor while under a vacuum, it has a low pressure switch which will keep it from starting. But of course you knew that, since you are smart enough to know what I did even though I didn't tell you every detail.
So you keep working for your dad in his shop.
B A N N E D
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
then second did you add any of the refrigerant in the lines them selves (the gauge's hoses), and since it sounds like you did it twice, you might have to add it up twice
third, you cannot just do a weight and expect it to be good, gotta get the pressures correct, and the weights are only a starting point fyi (some cars like it on the lower side of the weight range, then others like it on the higher side; the reason for giving a range (also helps compensate for any inaccuracies that your scale may have also)
and forth, the thing operates on the same basic principle as household a/c systems, just different pressures (which are quite easy to look up tyvm, especially with being on the internet), and smaller components, and the compressor happens to be driven by a gas motor instead of a electric motor
Helms has online info for $10 a day. Never used it myself, so I can't vouch for how complete the info is but I would assume it to be accurate. Caution: Changing out a TXV is a big job on cars. The refrigerant should be recovered, the dash has to come apart to get to the valve, and proper vacuum pulled and then the system has to be recharged. Not a quick fix. I changed out a valve on my 96 Lexus ES300 a few years ago and it took several hours with the proper tools equipment and the factory service manual. Good luck.
no you are not alone. Just another ass who assumes to much.
I have a digital scale and i measured in the remaining 4 oz, so i have exactly 22 oz, which is in the range on the label on the car.
I love you know it alls. Who can take a statement on a message board and go wild on what i did and didn't do.
By the way. I have a masters degree from ga tech. I would be glad to talk engineering or cs with you anytime. Since you're so smart try reading between the lines there.
And as always thanks to those who actually tried to help me. I wish there was a way to get rid of those who only want to assume they know exactly what i did and didn't do.
B A N N E D
but on some cars it is actually quite easy to do, cause you can get at it from the engine bay and such, but no such deal on our cars
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
first of all, how accurate is your scale ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Thanks. My dad has several recovery units. I have talked to several people and I realize how big a job this is, but Acura wants $800 to change it, so it might be worth it. I'm still debating. My biggest issue is that I don't have a mechanic that I trust and can just take the car to.
Thanks, from you I consider this a compliment.
![what](https://acurazine.com/forums/images/smilies/what.gif)
I’m sure you don’t care, but I am going to explain myself.
When I came to this site I was looking for assistance. I knew that I wasn’t an expert, that is why I was looking for assistance. Several posters here have been very helpful, but one poster decided to tell me that I didn’t know enough about AC, because I didn’t state that there was air flow.
This irritated me because, he assumed this this. I knew that there needed to be air flow. I just didn't state it outright. It is hard when you are typing out the description to determine what information is helpful and what to leave out. For example I really didn’t see the need to tell everyone the car was running, I assumed that most would take that as a given.
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Then you came along and seemed to only want to agree with the other poster. Your chivalry is impressive.
It was really funny that you made a mistake in your post also, (“Once you evacuate the system you cannot draw it back in with the compressor running” Especially since you cannot run a compressor with under a vacuum, unless, of course, you jump out the low pressure switch), since you were telling me how dumb I was.
Anyway. I’m not really that arrogant. I understand that I am not an expert, that’s why I was asking for help. What I didn’t understand what why other posters needed to tell me that I didn’t know enough. If you didn’t want to help or add anything to the post why didn’t you just move on???
Friesman2000, thanks for the help. Also sorry, I probably overreacted to the original post.
Rbc2000, you should realize that an arrogant asshole such as I, doesn’t care what you think.
To all, thanks for the help. Have a nice day.
Lets see, members point out things you have over looked or neglected to postn for what ever reason, Arrogant asshole comes to mind for me, so then you chastize them and call them stupid and to stop posting on your oh might thread. FU asswipe
First off, 25 psi on the low side is fine. The low end of honda's temp chart goes as low as 15 psi at 85 degrees F. I've had several cars in the past week that cooled fine and were in the 20 to 30 psi range; one stayed around 10. What's going on with the readings when it gets warm? A stuck expansion valve will usually cause a vacuum on the low side. If the clutch gives up, the pressures will equalize. There is an evap temp sensor to check too, but I,d have to look it up to get more specific. If your pressure stays around 25psi, is the temp door working? Is the water control valve staying open allowing excess heat inside the car?
It was losing pressure to the point of a vacuum on the low side. I would turn it off so that it could stabilize.
After a few days of thinking about it and reading. I decided that I didn't want to risk making a mistake in changing the expansion valve, so I took it to a "Professional"
He checked it out and said it was the expansion valve. They replaced it and it is now working great.
Just out of curiosity (SP?) I asked about the amount of 134a. He said that the charge was ok. (So maybe I'm not completely dumb
Anyway. Thanks for the help. I really learned a lot while reading about car AC and working on this one.
Sorry I was a butt at times. I'm not sure why some times I seem to take things very hard and respond negativly, while other times things will just roll off. Maybe I'm bipolar or something.
rbc2000 is my favorite poster.
Now I have to change the wheel seal on my Expedition. Anyone done that? Guess I will find a Ford site now.
I have learned my lesson. I will be nice on the ford site.
Honestly it had to be the heat that made me be such a butt. Heat and bad traffic drive me crazy.
Thanks all.
B A N N E D
I guess you will always believe that I am an ass, I'm sorry that I gave you that opinion. Maybe in the future I will have another problem and when I post I will not offend anyone.
I have learned my lesson. I will be nice on the ford site.![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
Thanks all.
Thanks all.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Bobinator
1G RDX Photograph Gallery
17
01-04-2021 01:30 PM
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
