aiming headlights
Old Apr 18, 2010 | 03:01 PM
Gil'sUA5's Avatar
aiming headlights
ever since i bought my 02 TL a few weeks ago my driver side headlight its basically on the floor all the way down and my passenger side headlight is a lot higher/farther on the road and is positioned correctly. now i know the driverside is supposed to be a bit lower but mine is basically all the way down so i wanna adjust it and raise it up a bit... how can i go about doing this?
Old Apr 18, 2010 | 09:04 PM
Gil'sUA5's Avatar
nvm.... fixed. took 5 min.
Old Jun 28, 2010 | 07:39 PM
thewrangler99's Avatar
how did i you fix it? both my headlights are way too low..
Old Jun 28, 2010 | 07:51 PM
fsttyms1's Avatar
the adjuster screws. If you pop the hood and look by the headlights there is a mark on the black cover above the headlight with a curved arrow pointing both ways, Those are the adjustment screws.
Old Jun 28, 2010 | 08:05 PM
is it a 10mm bolt?
Old Jun 28, 2010 | 08:06 PM
pictures would be really appreciated..
Old Jun 28, 2010 | 09:29 PM
01tl4tl's Avatar
look on top of the housing for the words UP DOWN and the arrows
now look behind that for a raised V track in the plastic rear side of housing
slide a small phillips screwdriver down the groove-at an angle as needed- into the gear teeth of the adjuster
Rotate screwdrivder handle to move headlight
simple
no 10mm anything on this job
Old Jun 28, 2010 | 10:11 PM
i was turning the whole bolt.
Old Jun 29, 2010 | 01:21 AM
01tl4tl's Avatar
was it doing what you want?
the screwdriver is acuras method,,go with it
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
