Acceleration problem
Old Nov 14, 2013 | 10:19 AM
jbwua6's Avatar
Hey people I have an issue
When I'm driving at highway speeds at about 70-75mph the car will begin to lose speed. It'll slow down to 40 and then will go slower and slower even though I'm hitting the gas and will eventually die. When I let it sit for a couple minutes and start it back up it'll run but once I start getting to high speeds again it'll do the same thing again. Anything I need to check or replace?
Old Nov 14, 2013 | 11:52 AM
666wokker's Avatar
Sounds like a blocked catalytic converter to me, I deal with that exact problem at least 5 times a year with the fleet I operate.
Old Nov 14, 2013 | 12:06 PM
jbwua6's Avatar
Thank you. I'll definitely check that out
Old Nov 14, 2013 | 01:33 PM
666wokker's Avatar
Couple good ways to see if that's what it is....
First, you could run the car for a couple minutes at idle, if the front of the cat is super hot, and the rear is not the same temp, there's definitely a blockage.
Second, you could have someone revving the engine while you stand at the tailpipe and see how much air is moving out, if it feels like next to nothing, there's definitely a blockage.
Old Nov 14, 2013 | 02:23 PM
jbwua6's Avatar
This is actually my friend's boyfriends car. They apparently solved the issue. The negative ground cable was loose, but I will have them check what you guys suggested also. Thank you for your help
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Papa Roe
Sep 26, 2015 11:45 AM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
