AC Works but no HOT AIR?
5th Gear
99 3.2 TL;
All of a sudden, the other night, the hot air turned to cold air!
I crank it all the way to 90... stil just cold air. Turn it down to 60 and it doeswhat it normally does (turns on circulation, AC, full blast ...works fine). However, NO HEAT! Just blowing cold air.
Any ideas? Engine temp checks out ok.
Thanks for understanding I'm COLD!! haha
Chris
Seattle, WA
Chris
Seattle, WA
Skeet Skeet Skeet
Originally Posted by MotionEffects
Could be a few things. Heater Core, Heater control Valve, Control assembly, Air register, etc.
5th Gear
Thanks for all of your help, guys. I got the DTC code which indicated a problem in the air mix control linkage, door, or motor. After doing so, I received honda_inspire99's suggestion. I found the little white, plastic lever that moves left & right. I could hear it was struggling when I changed the temperature, so I nudged it with a little brute force & it started moving as normal.
I THINK all is ok now. ...at least I know how to control the temperature regulator manually if need be!
Thanks!!
Thanks!!
Skeet Skeet Skeet
Thanks!!
Thanks!!
rockyboy
08-04-2024 10:35 AM
