AC issue
Old Aug 30, 2013 | 02:53 PM
David1221's Avatar
AC issue
Well last night my AC was blowing fine but this morning it is blowing warm air. I can hear the compressor coming on so I don't really know where to start....what do you guys think?
Old Aug 30, 2013 | 03:51 PM
closetprisoner's Avatar
2000 Acura TL
check heater core valve by the firewall
Old Aug 30, 2013 | 06:57 PM
David1221's Avatar
Found the problem....this is part of the wiring to the condenser fan. Where does it go? There is a blue and black wire going to the fan but there is a red wire with a silver tip at the end. Any idea where it goes?
Old Aug 30, 2013 | 08:11 PM
3.2TLc's Avatar
Chances are that the red wire goes to the AC compressor clutch connector or relay.
Old Aug 31, 2013 | 03:08 PM
David1221's Avatar
Ok. Can you tell me where that is located? Is it under the alternator or is it closer to the front like by the radiator? Thanks for the help.
Old Aug 31, 2013 | 04:42 PM
3.2TLc's Avatar
There should be a heavier black wire coming from the top front of the AC compressor. This is right below the alternator and goes toward the front. There should be a connector which the fan's red lead would go into. If ya can't get it from the top, try removing the lower plastic underbody shielding for access ?
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
