AC issue
Old Jul 5, 2012 | 09:30 AM
djescobar973's Avatar
Keep it flush!
AC issue
Whats up AZiner's.. Its been awhile. I have an issue with my AC. It stopped working during a drive. I hear the compressor kick in but then I hear the fan in the glove compartment area turn on faintly then die off. Not sure if it's the resistor or blower itself. Anything I should try before I start buying unneeded parts?
Old Jul 5, 2012 | 10:05 AM
01tl4tl's Avatar
perform glovebox removal via `cabin air filter` diy to inspect motor and resistor
before that:
a major prob is the power connector located under front edge of glovebox
Its wires are kinda tight--lots of heat generated with fan on 5 = burns up connector!
May have to unplug and inspect back and inside of part
acura sells a kit with new longer wires and both sides of connector
last reported at 8 dollars a month ago on here
easy diy splice
it thats blown/burnt, it may have taken out the resistor,,
remove blower motor panel and observe ridged heat cover over resistor
remove it and look for burn marks
other threads on cabin filter-resistor have pics if any question
Old Jul 5, 2012 | 10:14 AM
Keep it flush!
Cool ty..
Old Aug 30, 2012 | 12:16 AM
ml1006's Avatar
Any chance if you any pics available or what to look for or even a diy link? My AC stopped blowing in 110 degree weather today....Thanks in advance!
Old Aug 30, 2012 | 03:41 PM
01tl4tl's Avatar
see diy cabin filter replacement
once in there see motor and resisitor
good chance its the power plug connection under glovebox,,visable from outside,,
it cooks inside or on its back -acura has an update kit
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
