ABS and TCS Light stays on while starting in the morning
Hi,
I have read through many of the posts that relate to TCS and ABS indicator light that stays on. The issue that I have is that, when I start the car for the first time in the morning the TCS and ABS indicator stays on. But, after I drive for 10-15 minutes and restart again, the indicator lights goes off. Anyone with similar issues? Any possible causes or solutions to this?
Anyone having similar issue - The likely problem will be a bad ABS/Wheel Sensor. I had to have it checked by a dealer. Had to pay 280 to have it replaced. At least peace of mind.
audio4 (10-09-2023)
wheel speed sensor is a common problem
can be damaged by road debris or careless tech while doing brake job or crud eats the wire
dont need the dealer for most things-- if you are willing to get the codes read at parts store, we can help you along from there
at least its fixed!!!
grn99TL (06-15-2011)
changed the brake fluid in the last 3 years? do that and see if it helps
clean the contacts on brake level sendor on cap
have helper watch dash lights while you manually move the level sensor
mada51589
05-03-2022 08:54 PM
