Abs and Tcs
Abs and Tcs
I just got my wheel bearing replaced on the passenger side. After that, when I braked, the pedal start to shake at the point where the car is almost at a complete stop. After restarting the car, the shaking goes away but my ABS and TCS lights are on. Anyone have an idea what is wrong?
05 C230K & 09 135i 6MT
That's not balance. Someone didn't put something back together right and now an ABS system component is probably toasted. I'd definitely make them pay for the repair.
well when i had misfires on my car, my car was shaking, and cause of the engine shake, tcs light would stay on majority of the time, 90% then sometimes go away till it would shake hard again, ur tcs is fine, go back and get them to check it out,dont touch it.
TCS light will come on at the slightest hint of a problem in the TL... the key to this "mystery" is the ABS light. That light ONLY comes on when there is a problem with the ABS system - it will not come on for any other reason, not transmission, not misfires, etc. However, when the ABS light does come on to indicate there's a problem and the system has been shut off the TCS light will also come on since it piggybacks the ABS.
The car in question obviously has an ABS related problem.
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
