ABS Kicking In
ABS Kicking In
99 3.2TL
When I am coming to a stop the ABS is kicking in when I get to about 3mph. If I brake hard no issue. It only happen when I stop normally. When it first did it the ABS and TCS lights came on and then went off and have not returned. Taking up to the local auto store to pull any codes and will post them.
New transmission and half shaft was installed by Acura in the last month.
Appreciate the help.
there is your problem--the sensor is out of place after install of axle or they damaged it or the sensor ring
take it back- call and let the service manager know its a `comeback` and when is a good time for them?
it often takes a special `abs scanner` to get any codes for its problems
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Oct 8, 2015 11:16 AM
