99 tl license plate bulb
Whats up peoples, hopefully this is not out there because I searched and I kept finding DIY's for changing the license plate bulb for the 05, can someone please give me a link or explain how to remove the license plate bulb on the 99 3.2 tl???? Also the doors, I assume they just pop off.......right
Registered User
if u reach up above the license plate near the bulb theres a plug that you need to twist and pull up.. once its out theres enough slack to bring it out near the license plate to change the bulb.. you can use bulb 194 or 168... same for the doors, get a flat head screwdriver and pop off the covers and change the bulbs.. u can use the same bulbs as the license plate.
168 is brighter. Licences plate- If your hand it too big, there are two screws that hold the bulb and its base in place. If you pull out the base, you are able to clean the bulb's cover. 3 minutes tops
rcs86
08-02-2016 06:52 PM
