99 tl error codes
Old Jan 31, 2010 | 07:18 PM
sidxlr8er's Avatar
99 tl error codes
my car set for a week and a half when went to warm it up up it started reving form 1000 to 2000 rpms by itself. then the cel came on. i took it to autozone to have them read the codes and it came back with p0108- high input on map sensor, po122 low input tps sensor and p0505 iac malfunction. i took it to a friend to check out an unrelated problem and on the way the tcs light came on and everytime i let off the gas the car would shudder. i had noticed before all this every once in a while it didnt seem to have a lot of power on take off but it rarely happened. are all the sensors bad? maybe the throttle body? a bad wire?
Old Jan 31, 2010 | 08:52 PM
fsttyms1's Avatar
I would take off your IACV (idle air control valve) and clean it, reset the ecu and see if you have any of the symptoms come back.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
