90K Mile Service
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I bought a 02 TL, and the dealer said that the 90K service wasn't done. He said that it would cost @ $500, due to a new water pump/timing belt. Does anyone know if this seems reasonable? Also, can these parts be replaced by myself (avg. car tech. knowledge)? Any and all help is appreciated.
Welcome to the forum.
Now to answer your question. If you are fairly mechanically inclined this can be done at home. Its really not that hard, just time consuming due to the location. If not check your local honda dealers as they often have cheaper hourly rates or independent mechanics that you trust.
90 k service
500 for timing belt and water pump is correct here in new jersey anyway at an independent (our dealers charge 800). edmunds.com has some info on maintenance frequency and cost; fyi at 120,000 miles for my 2003 tl the lower ball joints should be checked
add timing belt tensioner pulley, NGK Iridium spark plugs- air filter- the basics- check the cabin air filters for sure!
all that stuff is due around 100k some go less some go longer
read thread Seafoamed the Ol TL and buy 3 cans (20bucks) to make car like new
And the all important Brake Fluid Flush !!!!!
check the thread- completed 105 service, it has pics and details
Also see thread Thermoblock spacer and EGR cleaning
fsttyms pulled his motor at 200k in perfect condition and slipped a 6speed in his 2000 TL
Some people get incredible miles out of a part while others get the severe service lifespan
Originally Posted by Mike B
Any DIY timing belt threads around here?
I made a list of:
Timing belt
Tensioner
Pulley
idler
3 timing cover gaskets
water pump
Any suggestions? Adds or deletes?
I'm hearing what sounds to me like a pulley/bearing squeal, but I'm not sure where from. To be honest, it's one of the reasons I'm considering doing this job since if it's the water pump I can fix that and take care of the 'maintenance' at the same time, without taking the chance of getting the call from the wife that she's on the side of the road with an over heated car and I'm stuck with a 'right-now' repair. If it's one of the other pulleys, those are quicker and easier to take care of if they suddenly fail (Makes sense in my head anyway, even if it doesn't in print
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Car is at 138K, 3 trannies, but other than that no issues except the a/c blower I fixed last night. Still on factory hoses and belts, and they all look straight, smooth, no cracks or swelling
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
