5000K HID conversion kit?
Old Sep 18, 2011 | 11:47 PM
jdubbs11ghost's Avatar
My driver side headlight has moisture in it and has put out the bulb. instead of buying oem bulbs to replace, Ive decided to upgrade to HID. Do the ones at this link look like a good reliable set or should I spend my money elsewhere? thanks.
http://www.hiddepo.com/p500/Acura-50...duct_info.html
Old Sep 19, 2011 | 10:41 AM
01tl4tl's Avatar
we already have HID low beam system, you just need the correct bulbs for it
BUT
with moisture inside housing you will also have water on the ballast and capacitor area- causing their failure as well
get an entire new hid kit, new 5000K (kelvin color scale) bulbs, ballast, connector wire etc for both sides,,get the relay kit too for awesome direct batt power to lights!
all together will run under 100 bucks!! ck our sponsor hidextra.com
look online for coupon codes too
you need to reseal the housing lens, see diy for options
the new parts are waterproof- except the bulb~
Old Sep 19, 2011 | 07:26 PM
BUT
so get http://hidextra.com/ for 59.99. includes 2 hid bulbs, and 2 ballasts, get http://www.hidextra.com/hid-relay-ha...9fad3ff0c33053 for 16.00 (only need to buy one total?) and get http://www.hidextra.com/d2r-d2s-conn...wire-pair--345 for 15 for pair. thats all i need?
Old Sep 20, 2011 | 10:16 AM
01tl4tl's Avatar
no, just the kit ---it includes the connector wires, ballast and bulbs- everything you need to make it work for BOTH sides of the car
ONE relay kit is a good idea for preventing issues, and better power source for lights-
which bulb base you need depends on car year, ck owner manual or car specs online
dont expect them to know..
I call their 800 for best service and order processing that results in same or next day ship from the northern Ca location
you will need to cut a small groove in plastic of housing for new, larger connector wire to clear thru the old fitting, a file works well, dremel etc awesome
DO use zip ties to hold the ballast to the frame rail!! tape does NOT HOLD,
slip the rest of the wiring under the housing as you slide it back into place
ck online for hidexta.com+ coupons for 10% off codes
Jul 16, 2017 07:33 AM
rhdune16
Sep 28, 2015 11:31 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
