2003 TL-S sputtering--3 days to fix
Last Monday I was driving on fumes....literally. The gas light was on and the neddle was way past E. I stopped finally at my usually gas station and filled up. 6 miles later, pulling into my driveway, the car sputtered. I shut it off and didn't start it up again until the next morning.
It shook like crazy. Engine light blinks and VSA light came on. Codes show misfire in cylinders, 1,4,3,6. And a multiple misfire code 0399.
I thought it was bad gas so I drove it until 1/4 tank and filled up again today (different station). No change. I have an appt with the dealer next Tuesday morning. What can/should I try until then? Coils?? Plugs are 1 year old. Perhaps the gas fill up and the problem were just a coincedence??? HELP please!!
97k miles on it.
97k miles on it.
ck the gas cap rubber seal condition, and is the cap on the required 3 clicks
fuel injected cars hate being run low and especially out of fuel
running it down that low may have gotten crud past the filter sock
I would run redline SI-1 fuel injector cleaner, or Seafoam, thru 1/2 tank of gas to full bottle of either of those
see if an injector or something got bad things in it and this cleans it out
You can reset the ECU by removing the CLOCK fuse on passenger end of dash-
after a minute put it back in
Tier 1 brand gas is preferred by acura for the TL
it contains more cleaners in it than tier 2 cheap off brand gas does- that has the govt minimum
`They` know e10 gas is bad for combustion and make the oil companies add cleaners to all gas!
Looks like it was a bad coil in cylinder 4. This shows that even a multiple misfire can prove to be one cylinder. The plug was darker and wetter than the others which meant that gas was being sparked/burned. I changed that plug first--still sputtered. Then put a new coil in and I got lucky-- that was the bad one. No sputtering. I change the remaining two front plugs and doing the back three tomorrow AM. Thanks for your replies!!!
6spder
1 Post
those multi misfire codes are most often 1 coil failure, and the system only knows there is a problem
Or its a designed in code feature... so the dealer can sell you 6 coils!~
P-- you did the exact right thing for diagnosis- start pulling plugs till you get to the wet one--the plugs tell you many things about how the car is running
Its not going to be just a plug when its wet like that- but hey - everyone gets to dream!!!
totaled: no known issues to you,,and- the car runs its best- are different things
Can't wait to cancel my appt at the dealer...haha
It has run absolutely fine for me for nearly 20K miles (since I've owned it) using various fuels. Co worker's car also runs fine for well over 100K mi. (since new) on same fuels. Only issue that happened in my area was excess sulphur was in Speedway's fuel a few years ago. Ruined fuel gauge sending units. They paid for repairs. Isolated incident.
I wonder if sulpher content is an issue in other gas brands?- we have someone else with a fuel sendor problem ..
totaled- try a few tanks of chevron and see if your mileage changes
thats a common report on the better gas
Of course you know my love of redline SI-1 in the gas and seafoam elsewhere
if you have a plug in ocbd2 scanner you can drive with and monitor to compare gas ---
that would be interesting
sorry to hijack the thread, but i went to the extent of replacing all 6 of my coil packs after the car threw up 8 codes related to the misfire. first 6 were misfire in cylinder 1 through 6, second was multiple misfire and third was ignition module. the thing is still throwing up a CEL with the VSA light, im lost as to what i should do at this point. plugs were changed about 35,000kms ago.
6spder
1 Post
I tell people all the time:
codes are clues and not a disgnosis- they put your mind to work deciding what caused those codes to combine??
need fresh code report
If you had a bad coil the plug could be fouled and you wont know it
remove spark plugs and inspect wear- wetness means bad coil
bad coil could mess up plug electrode tip--compare each
You are running NGK Iridium or NGK Platinum plugs right?
If not ngk or denso pull them out- thats your remaining problem
Bosch die way early and make the car run bad-- as an example
2 brands allowed- denso (more expensive/last less) or NGK- which came stock on the car
in platinum, and we can upgrade to Iridium if desired
got any good fuel cleaner pushed thru yet?
