2003 TL-S Giving Misfire and VTec codes
Old Apr 4, 2013 | 08:49 AM
Corey2GTLS's Avatar
Im getting codes for misfire on cylinder 1,2 and a random misfire code. im also getting a code for vtec system failure. the car drives fine even when I get on it. that's what is throwing me off is that if it wasn't for the codes I wouldn't know anything was wrong with it so what do I need to do too fix this. Thanks guys
Old Apr 4, 2013 | 08:52 AM
maybe vtec solenoid?
have you checked your oil level?
maybe coilpacks are bad?
Old Apr 4, 2013 | 08:59 AM
Corey2GTLS's Avatar
how do I check vtec solenoid? I changed all the spark plugs not even a year ago but didn't change the coils. oil level is fine just changed the oil
Old Apr 4, 2013 | 05:36 PM
3.2TLc's Avatar
Reset the ECU and see if the code comes back. The VTEC solenoid is just above the oil filter. You can pull off the connector and check resistance values to test. Chances are that the VTEC solenoid's filter is clogged. Maybe cleaning it, along with an oil change will resolve your CEL code.
Yikes
May 3, 2021 04:29 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
JnC
Sep 11, 2015 06:06 AM
merc009
Sep 3, 2015 01:44 AM
VladkaR
Sep 2, 2015 11:36 PM
