2003 TL-S engine cradle/ subframe rust
I found a spot rusted right through a subframe/engine cradle part when I had the front passenger wheel off. I found out it is a common issue for this car. However, I haven't found out what part it actually is. I don't have a good way to get under the car right now. I've tried parts sites and ebay but I'm getting confused as to exactly what crossmember/cradle/subframe I need to get. I plan to get it from a used parts place. Any help on identifcation? Thanks.
![](https://lh5.googleusercontent.com/-BEaWKgiTY6I/Umyh3VAzZJI/AAAAAAAAPZE/3hU8igk-MQg/w1152-h864-no/IMG_20131026_145745550.jpg)
Mr.Helpful Diagram
Welcome
heres what you need to replace
![](http://imagizer.imageshack.us/v2/800x600q90/4/5use.jpg)
Yeah, as ErickUa5 circled: the front subframe's rear beam is the part.
There has been problems with rust in this area, so be careful when buying a used frame beam. You won't have any problem finding a replacement part as any '99>'03 TL, CL or '98>'02 Accord should interchange with yours.
Removal of the frame beam is a bit labor intensive, but possible. There is good info for "DIY" by searching previous threads on the subject.
Hey Iamayak, let us know how ya make out with replacing the rusted front sub-frame.
It always helps others with a similar problem when the time comes, Thanks & good luck !!!
Mr.Helpful Diagram
Since the subframe is going to be out its the perfect time to inspect the rack and pinion for leaks and cracks on the boot.
If you see power steering fluid in the boot then replace the rack, after everything an alignment is needed.
mrkingstonvi
02-22-2016 01:53 PM
LECKEY73
02-22-2016 01:32 PM
