2003 TL-S A/C not working- ECU needs change?
Old 04-25-2018, 09:04 PM
nishant11's Avatar
Posting again to correct location-
After winter when I turned on A/C first time on my 2003 TL S it did not work
I do not hear clicking noise when I turn on A/C.
I took it to the mechanic and he checked it and informed me that ECU is not sending out signal to energize A/C relay and that ECU needs replacement.
I would like to know how accurate his diagnosis is and whether this is a known issue?
ECU change and programming is as expensive as transmission replacement and I am very hesitant to do it
Old 05-10-2018, 07:00 PM
frankjnjr's Avatar
Sorry Nishant11m , just reading your post today. To my knowledge, ECU problems are quite rare, in the 2G TL models. If, indeed, it is a (RARE) faulty ECU, which is causing the A/C issue. Not certain where your Technician is getting his information, but a replacement ECU should not be all that expensive. You should be able to locate the correct part number, "ie" one that matches yours, for less than $75.00. An Acura Dealer, will normally charge, between one and two labor hours, to install, and program it.
Old 05-10-2018, 09:13 PM
01acls's Avatar
Pull the clock fuse for 10 seconds to reboot the ECM.
nishant11
05-04-2018 12:00 PM
handsom-hustla
03-21-2016 06:50 PM
PhilWithers
2G CL Problems & Fixes
03-11-2009 04:31 PM
Caddyİ
02-07-2003 08:44 AM
Quick Reply: 2003 TL-S A/C not working- ECU needs change?
