2003 Acura TL-S. Excessive oil in Upper Intake Manifold?
Hi guys, joined up just to ask a couple questions.
Im currently using my aunt's 03 TL-S while my WRX is in the shop.
The car has 294k miles on it for reference.
I was just changing the plugs, and for shits and gigs I took off the Upper Intake Manifold cover to see what was going on in there.
There seems to be a massive amount of oil residue in the manifold.
Here are some pictures to help. All i have on me is my droid, sorry for the crap quality.
Is there anything i can do to give it a quick clean besides going to town with some towels?
And any idea what is causing this?
Also, I noticed at idle it "stumbles" for lack of better term.
RPM's are consistent, but it almost feels like it is missing.
I did get CEL's for cylinder 2, 4, and 5 misfires, but i unplugged separately each coil pack while the car was running and each one cause the it to bog down, so all the packs are good.
It was doing this before i changed the plugs and is still doing it now.
I used the NGK Iridium plugs as required.
Oil is changed every 4500-5000 miles according to my aunt as my uncle drove it back and forth from long island to CT 5 days a week from its purchase in 03 up until about 5 months ago when he got a 2011 TL.
Any help is appreciated.
silvercookie (03-12-2013)
And i actually have a can of seafoam sitting right next to me.
Do you think the Aerosol version would be good to clean all the caked on oil?
Or should i just pour some into a cup and go to town with a tooth-brush?
Must say it is a different world between Subaru's and Acura's.
Excessive oil? No, this is normal accumulation with mileage. Mine was exactly the same as yours. But it does need regular cleanings...perhaps every 70k or so. Do the diy listed here and it will turn out spotless. You will need to remove the intake to do this properly. You don't need to buy any gaskets other than the throttle body gasket. Remove and clean throttle body and iacv valve, and egr valve too (need to buy an egr gasket).
The following 2 users liked this post by victus1:
shamal (10-31-2014),
I was actually thinking of removing the intake manifold and giving it a thorough cleaning.
Anyone have a link to the DIY? Been on forums for 6 years and still have yet to.have the search cooperate with me
Registered Nonmember
The following 2 users liked this post by TheMightyQuinn:
If you still have a slight misfire after you do the egr cleaning, you should check the valve adjustment. With the mileage you've got, you probably have exhaust valves with too little clearance which will cause a miss.
silvercookie (03-14-2013)
Close to 300k on '03........clogged EGR
Yeah, as these guys are saying....don't be concerned about the oil, but the EGR passageways definitely require a good cleaning. You'll notice a big difference in what you described as missing at low rpms and idle.
Treat Auntie to a complete tune-up, new NGK's.....air filter.....pcv valve and perhaps even adjust the valves. How is the tranny and T-belt ?
The oil is normal.
Timing belt was done not too long ago i believe. Ill have to check.
New-er trans was put at 198k miles when the original failed.
Air filter was changed last oil change.
Well it was definitely an experience to say the least.
Have to say, it was relatively simple. The biggest PITA was cleaning the actual manifold.
So much oil and crud built up.
It is running so much better and smoother. Threw a can of seafoam in with 1/2 tank left and added some gas to mix it up.
Thanks for all the info guys. Really appreciate it.
1 can seafoam to half tank gas is Cleaning doseage of 2oz per gal
thats max needed, more doesnt help
those pics should go in a thread of what a clogged egr looks like!
did you run a wire coat hanger thru the length of the egr passage?
I had one of those pipe cleaner brushes with soft metal wires on it. Gave it a good cleaning. The amount of crap that came out was disgusting.
sounds like the actual tool to clean EGR passage,,good job!
a 2nd treatment of seafoam in gas will finish off any residue
in 6 months throw a can in the gas for maitenance dose
ethanol leaves behind a lot of crud,,seafoam removes crud
might want to -at next regular oil change- add 1/2 can seafoam to oil.
as you have high miles, install any brand oil filter
drive up to a week/200 miles,, then change oil and filter -
oil must be warm at change
makes a major differance
I know on turbo cars it destroy's the seals in the turbo, wasn't sure if it was say for these.
I will definitely do that. This thing needs a oil change severely.
Hmm, guess you can't edit posts on here.
Forgot to add that when i reached about 1/8th of the tank left with seafoam in it, at high rpms under WOT i could see smoke coming out from the exhaust from all the leftover crap in the manifold being sucked in and burned off.
The difference is unbelievable.
I actually got bored last night and took one of my spare intake filters from my WRX and stuck it on the end of the throttle body just for the hell of it.
The sound is incredible, and the top-end definitely increased a little bit.
Never really understood what the big rave about V-Tec was, now i do haha.
Who knew a auto 5 speed could chirp/spin 2nd without VSA on.
I have to say, even though this car is only a temp for another week or so, i was extremely compelled to start ordering parts for it lol. headers/catback, CAI, that A-spec replica lip kit etc haha.
I don't think my aunt would be too fond of it.
seafoam is excellent in the oil when used as directed
suggest new filter for first time as much crud will need to be captured!
I dont know about turbos and seafoam,,ck www.seafoamsales.com
maybe not a vac port method,,,but fuel and oil?
now there appears to be a severe oil leak coming from under the car. le sigh.
My aunt brought it to the shop she uses and dropped it off. We will find out the diagnosis tomorrow.
Yea under the car. It is all over the bottom of the block and dripping/blowing from the wind all the back down the mid-pipe and on the cross-members.
Last thing i need right now.
It is definitely motor oil though, not trans fluid or anything else.
What blows my mind is that it literally happened out of nowhere.
Left my house, not a single drop under the car. Got to my aunts house and parked, went to move the car 2 hours later and there was a small puddle.
Should have taken pics but i completely forgot.
If i had to describe where it seems to be leaking around it would be if you are looking at the front of the car, straight down from the middle rear sparkplug.
Hmm....too much WOT for Auntie's 300k TL ?
Forgot to add that when i reached about 1/8th of the tank left with seafoam in it, at high rpms under WOT i could see smoke coming out from the exhaust and burned off.
I actually got bored last night and took one of my spare intake filters from my WRX and stuck it on the end of the throttle body just for the hell of it. The sound is incredible, and the top-end definitely increased a little bit.
Never really understood what the big rave about V-Tec was, now i do haha. Who knew a auto 5 speed could chirp/spin 2nd without VSA on.
Any 10 year old 300k motor is going to potentially have some weak gaskets or seals......maybe ya found one of them !!!
looks like you have some carbon build up in the egr ports and passage to the egr valve. I would make sure the plenum gasket is on in the right direction and all egr ports are open and free of carbon. my 03 cls had a major issue and I found the plenum gasket was installed backwards. it is almost identical looking when installed wrong leaving some egr ports open and others covered.
justnspace (08-06-2014)
saberlove
03-11-2021 09:29 AM
