2003 acura tl 5speed auto
Did complete rebuild on transmission no problems. Works fine in R 1 and 2 . When you put in D5 D4 or D3 it engages then goes right into neutral. Has set code p1751 so we replaced shift solenoid valve B and clutch control solenoid A and B but it still set code p1751. Any ideas out there will be greatly apreciated.
Could be the wiring to the solenoid.
So your "complete rebuild" didn't include new solenoids?
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
Welcome to the forums.
This thread has been moved from the 3G TL Problems & Fixes Forum to the car specific forum applicable to your vehicle.
If you did a complete rebuild with new clutches, steels, o rings, filter, gaskets and a reman tc then you should not be having this problem. You will most likely have to take the case apart again and find any mistakes.
