2000 TL Overheating
2000 TL Overheating
Greetings. I recently started having issues with my 2000 TL overheating. First I realized that the drivers side fan stopped working so I replaced that. The fan works now, but it still overheats after about an hour driving in the city, and also the fan keeps running after I shut the engine off which never happened before. I also replaced the thermostat and the fan control switch located on the thermostat housing, as well as new coolant and burping the system. I am now out of ideas. Any insight is appreciated. Thank you.
Hmmm, if ya replaced the cooling fan, ECT thermosensor switch, thermostat and burped the cooling system...what's left ?
IDK, Try pressure checking the system and replace the rad cap ??? Perhaps the radiator is restricted or the water pump is faulty ?
Any other relevant issues that may have just surfaced recently ?
Usually auto parts stores will let you borrow a combustion gasses kit.
You should let your car run, cover your exhaust with your palm and let moisture collect on your hand. If it has a green tint or smells sweet, coolant is being burned, which is either a warped head (unlikely unless you seriously over heated your car) or a head gasket.
Though, TLs aren't really known for head gasket failure, but I suppose anything could happen.
Best of luck, and keep us updated.
3.2TLc (10-16-2013)
Was going to suggest having the radiator pressure tested cap and to check your cap. Glad you got it figured out.
Mike Bertram
09-10-2015 09:27 AM
