2000 TL Navagation System
I have a 2000 TL with factory Navagation system, after I took out the Nav. DVD to check the Ver. and put it back in, the GPS lost its location, need to reset !!!! IS is normal? Can anyone can show me hoe to reset the "Navagation system"?
Navigation Update
I have the earlier version of the DVD (Black 2.40), if I want to purchase the newer version 2.5, it will cost around $200.00 from the dealership, is it worth the spending? Is the 2.5 is much more detail than 2.4 ?
Please help...........
Check Paul Mooney's helpful Navhelp.com web site. He lists the improved areas with each release.
But 2.40 is a pretty recent release. Unless you've run into problems, I would be tempted to wait for a newer release.
Still not working
I let the car park with engine running for over 30 minutes for the GPS to update my position on its own, but still not working. I re-insert the DVD, make location correction (input current location). Nothing is working !!! It keep reading I am in other City which is over 100 miles away !!
Please Help !!!!
Please Help !!!!
Please Help !!!!
Please Help !!!!
Have you taken the car on a drive yet?
And I know that I've seen other threads regarding this same problem. Search the forum and see what you can find.
Good luck!
read the procedure in owner book
key must be ON but engine not running- insert disc- start car- leave running in open space- a place you know was on the gps when you stopped!
You order the new disc via acura corp- see the store portion of acura.com after you register there- it list changes to each version
check recall section and make sure you are current on things there as well
http://owners.acura.com/registration...erstepone.aspx
SiClone
10-01-2015 10:22 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
