2000 High beams problem
Old 03-22-2011, 02:04 PM
Brakoo's Avatar
It seems like my passenger side high beam is dying on me. When I switch the high beams on it's not always on so I figured I'd get a pair and change them.
Now I started with the passenger side since it was the easiest one to access. I managed to get the bulb assembly out of there but for some reason it seems like the bulb is stuck in the connector pretty badly. I pushed on the blue tab that seems to be holding the bulb in place and even there I couldn't get any movement from the bulb. Is there a part I'm missing here and some precautions that should be taken in consideration ?
I did search for a guide on how to replace the headlight bulbs too and I seem to be unable to find anything. Anyone able to help me with that ?
Old 03-31-2011, 12:40 AM
junteschan's Avatar
There are 3 screws you need to remove first then the bulb.
pstomps
02-20-2017 03:29 AM
brandnewcolony
09-12-2015 10:39 AM
theinsvnity
09-10-2015 10:22 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: 2000 High beams problem
