130K Maintenance
130K Maintenance
HI,
I have a 2000 TL with 130,000 miles. I want to keep the car going for as long as possible. Since I bought it in 2003 with 38K mi., it ran perfectly. At 100K I changed the timing belt and water pump, hoses and belts. Flushed the transmission fluid and radiator. What maintenance do you recommend? Thank you.
B A N N E D
so i would do the brake fluid, and p/s fluid also
and have you also changed the plugs recently too
and cleaned out the EGR passages also, since they like to plug up over time on some people's cars
I am planning on cleaning the EGR port next, the car starts rough when it's cold. Another member advised me I don't need to replace the gaskets just reuse the old manifold gasket, is that a good advice?
How do i evacuate the PS fluid?
that fi cleaning did the valves for you too
ps fluid has a few recent threads and a diy somewhere here
brake fluid is easy diy as well
or 100 bucks each at a shop
your 2000 has 6 egr ports, not 1 as only the '99 has
acuratl26
04-23-2020 07:30 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
130k, accura, acura, cl, maint, maintaince, maintainence, maintenance, mdx, mi, mile, rsx, service, tl, tsx
