03 TL-S w/105k miles
Old Mar 14, 2008 | 03:15 PM
Mikaveli54's Avatar
2003 Acura TL-S
What up everyone!
I have 2003 TL-s and i just hit 105k miles. What should be my next step as far as a tune up? I would like to keep my car up to par and running strong. Also, I had my recalc done with the 2nd gear problem; and I still had to replace the Tranny, but now that im on my 2nd tranny (about 7,000miles on it) when im in 2nd gear my steering wheel gets a little shakey.
Old Mar 14, 2008 | 05:37 PM
01tl4tl's Avatar
welcome
So to be clear- you had 1 warranty trans replacement and that has 7000 miles on it?
If you suspect its trans in any way- go to the dealer- warranty trans has its own warranty
and they will go for a drive with you.
Shake at speed is often tire wear problem or tires need rebalancing.
You live where the roads are not good! Once a year balance and alignment is not unusual
105k miles is: The Big One
water pump- timing belt -some tensioners- spark plugs- valve adjustment etc. expect $1200 if a shop does it all, or do the basic things yourself and save 200-400 on the total.
Old Mar 15, 2008 | 02:44 PM
Mikaveli54's Avatar
2003 Acura TL-S
Yea, Im on my 2nd trans.
Im goin to take it back in so they can drive it.
another problem that Im having is my headlights. I have moisture build up in both headlights and I think my ballast went out because i replaced the bulbs with new ones and still no lite. Have u had the same problem?
Old Mar 18, 2008 | 10:40 AM
acutee's Avatar
moisture or condensation in headlight is a known problem with second gen TL. If you did not fix the problem promptly, the water will damage the ballast or igniter or both.
mada51589
Jan 9, 2025 04:40 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Legend2TL
Nov 20, 2015 07:31 PM
mugen_kid
Nov 13, 2015 10:38 PM
JnC
Sep 11, 2015 06:06 AM
