01 making a odd wuhwuhwuh noise
Old Aug 8, 2011 | 09:05 AM
BarryTL's Avatar
My car is making an odd wuhwuhwuh noise from the front .. I do have a bad axle in the front driver side that iam replacing this week.. That was causing alot of vibration.. Now im getting this noise is it axle related or is it a wheel bearing! ?? Thanks ahead of time
Old Aug 8, 2011 | 09:17 AM
01tl4tl's Avatar
ck for wheel movement with the car jacked up
cant be sure without a stethascope, and the other known prob fixed
Old Aug 8, 2011 | 09:19 AM
BarryTL's Avatar
Okay ill check
Old Aug 8, 2011 | 09:49 AM
BarryTL's Avatar
Also when i break i get a vibrating inthe wheel axle related? I dont want to think its a rotor because it only does it when slowing down from fast speeds and idk lol its like one thing after another by the time im done i will replace everything!
Old Aug 10, 2011 | 07:49 AM
BarryTL's Avatar
i got no movement in the wheel while jacked up
Old Aug 10, 2011 | 10:23 AM
fsttyms1's Avatar
sounds like a bearing issue, but with all the other issue you have you need to get them fixed first just to eliminate them from the list.
Old Aug 10, 2011 | 11:48 AM
01tl4tl's Avatar
if the cv bearing has been bad a long time and you keep driving-
its vibration, and resistance to normal motions, can take a toll on the hub bearing
at this point- may as well replace it while the system is apart for axle
see diy section
Old Aug 11, 2011 | 12:12 AM
57 Handyman's Avatar
BarryTL,
Is the vibration also felt in the steering wheel? Also, do you get a pulsating feeling in the brake pedal? If yes, then the problem may be warped rotors.
My wife's 02TL has consistently run into warped rotors ever since we bought it new. Each time, the rotors were resurfaced them and they run smooth for 30-40K miles. So far, I've gone through two sets of Acura rotors with each being resurfaced once before swapping them out; all under warranty. The current set are NAPA replacement rotors and pads. Same problem...pulsating pedal and vibrating steering wheel.
I'm beginning to wonder if an ill adjusted front hub or bearings are the real culprits.
Any thoughts?
Old Aug 11, 2011 | 03:08 AM
01tl4tl's Avatar
hub runout, crud on mounting surface
acura rotors not very good,,not worth resurfacing
napa varies in quality depending on maker and price
any good mechanic can listen with a stethascope and find out if bearings are at fault
even blasting the lug nuts on can warp the rotors!
Old Aug 11, 2011 | 03:09 AM
01tl4tl's Avatar
do you flush the brake fluid every few years? make sure calipers are operating properly?
Old Aug 15, 2011 | 01:17 AM
03TLDayton's Avatar
8th Gear
Opinions Wanted: Rebuild all major suspension parts at same time?
Hey you guys are good; much better than average I must say.
Should I replace all below items during one all-out, jacked-up, event!
2003 TL-Premium
155,000 orig miles
Must Do:
1) Brakes, pads, rotors (rotors are 155k miles old; finally at min. thickness.
2) CV joints, boots, and Axles (getting some whining noise; small grease leak at outer boot)
3) Wheel Bearings x 4 wheels ( getting some of that Wha..Wha..wha noise)
4) Shock Absorber: (maybe even stock ~$80; lasted a long time; >150k)
Question: Are there really choices for better ride or/or performance?
5) Replace brake fluid with my new vac pump.
Maybe Dos:
a)Sway Bushings: Done once at 60K miles
b)New Calipers: Are those two pistion calipers really any better? Does anyone had a joyful, reliable, and lengthy, braking experience with the alternate calipers that supposedly bolt right on. Correct? (03 TL) Is there more brake feel? More even forces applied to pad? [My 67' Mustang Fastback GTA actually had 4 pistons on each side, whatever that means?]
c) New tie rod ends (inner/outer) One side was already done this summer.
d) Stainless Steel Brake Lines.
Check; maybe leave alone if okay:
a) Balljoints,
b) Control Arms,
c) Bushings,
d) Strut Hats
e) Hardware
Question1:Which items should be Dealer-only? which should be aftermarket? Suggested parts and URLs are very welcome?
Question 2: Is there something else I should check or overhaul while I've got the front end disassembled? (those AT switches?, or solenoids?, ATF filter, etc.)
Old Aug 15, 2011 | 11:51 AM
01tl4tl's Avatar
why not have a mechanic look at it on the lift for needed parts and replace those
legend calipers rock,, and for the same price as TL calipers!!
more pistons = better force distribution to pads
search or scroll for the threads on subject,
I have them with RacingBrake brand pads and rotors-from MrHeelToe on here,,-now it stops like it should!!
SS lines with them YES, dont swell like rubber so always good pedal feel
and same result from your input to caliper regardless of brake temps
Old Aug 15, 2011 | 11:53 AM
01tl4tl's Avatar
for the total cost you are looking at- are you keeping the TL as a 400 kmile car??
then its worth making everything right at once, a new car when done
are you DIY or paying someone or someplace?
Old Aug 15, 2011 | 12:01 PM
01tl4tl's Avatar
clean all the trans shift selenoids/pressure switches and new filter
Old Aug 15, 2011 | 11:35 PM
03TLDayton's Avatar
8th Gear
Yep, It would be a DIY job. Do I denote a lack of confidence in 03DaytonTL? Just kidding.
I estimate about $1200 +- $300 parts. Dealer service would be impractical and cost-prohibitive. Plus I wouldn't haven't any fun with my tools =, including my new Alum Racing Jack, Aluminum Jack Stands (they may fail, but they look pretty) and 24" Breaker Bar. Not to mention my new vac pump that just sucks...fluid. The DIYs are great. I use that as my first recourse (next to my Acura SErvice Manual)
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
2012wagon
Sep 29, 2015 04:21 PM
MyGuti
Sep 12, 2015 06:52 PM
Mike Bertram
Sep 10, 2015 09:27 AM
