00 TL everything electrical flashing
Old Jun 30, 2008 | 02:14 PM
dusik77's Avatar
6th Gear
Hello!
I had to brake hard yesterday to avoid hiting this car in front of me and right after that everything electrical in my car would flash for a split second and come back on.
Car runs fine but everything in the car would flash and ABS and TCS would flash and then its fine.. It happens almost every 20 seconds.. In the morning I noticed that car would start one time and it starts if I try again. Another thing, after I turn my headlights on it would do that again(not all the time)
PLEASE HELP if anyone had similar problems or knows what can be the problem..
Maybe ignition switch ( thats what I came up from looking around forums)
Thanks in advance
Old Jun 30, 2008 | 02:38 PM
fsttyms1's Avatar
Make sure the battery connections are tight and corrosion free. Check the ground wire as well.
Old Jun 30, 2008 | 02:58 PM
dusik77's Avatar
6th Gear
I checked and cleaned battery connections.. Checked 2 ground wires that go from the battery, they look OK.. Drives me crazy..
Old Jun 30, 2008 | 05:25 PM
fsttyms1's Avatar
Is it just the ABS and TCS that flash? or is it every thing else as well.
Old Jun 30, 2008 | 07:51 PM
dusik77's Avatar
6th Gear
ABS and TCS will flash and stay on most of the time. But everything in the car will shut off for a split second and will come back on..
Old Jun 30, 2008 | 07:54 PM
dusik77's Avatar
6th Gear
I changed ignition switch from Autozone made by duralast and kept doing the same thing.. I opened the fuse box and switched lighting 1 relay and horn relay (since they are the same) and everything works fine... at least for now.. will try tomorrow again and see what I get..
Do you guys thing lighting 1 relay would do something like this??
Old Jun 30, 2008 | 08:15 PM
01tl4tl's Avatar
After a hard stop like that I would look for pinched wires - the battery can shift and get something loose-
something could have been on the road and snagged a wire to the speed sensor....
Look under the car for damage
Old Jun 30, 2008 | 08:33 PM
dusik77's Avatar
6th Gear
I will put it up tomorrow and take a look close under the car.. Thanks for your quick reply 01tl4tl...
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
ceb
ILX
Sep 27, 2015 10:56 AM
