AMGalas header install
B A N N E D
1 Post
Well this install was almost as bad as mine. it took about 11 hrs, most of that time was devoted to taking out 2 bolts connecting the cat to the down pipe. once we were able to drill those out, the rest was cake. here are some pics from the install.
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1779.jpg)
Hes a happy guy (hasnt gotten to the 3 cat bolts yet lol)
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1778.jpg)
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1780.jpg)
Me trying to get the cat bolts loose
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1781.jpg)
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1784.jpg)
torching the stupid bolts
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1786.jpg)
At this point we're about to cut his tire and leave
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1787.jpg)
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1789.jpg)
Now this is how you install the back header
![](http://i20.photobucket.com/albums/b221/bimmerman318is/ClubViS/102_1792.jpg)
11 hours huh? I could have preformed the 6 speed swap in that amount of time ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Good job sticking with it and finishing it
Lamborghini Aventador FTW
Good job sticking with it and finishing it![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I've read that a lot of you guys don't use the hanger because it gave some resonance. Well I don't know if you knew this, but the hanger mount has about 1/2 inch of play if you loosen its bolts and move it left or right. This may help you align the hanger better so you can still use it but without resonance.
Originally Posted by KSuchdeve
One question, how many of the new bolts do I need to go get? I see the six that came with the package, but do I need to get any more than those?
No He Can't
Yea I was gonna get 10X40 1.50 pitch.. so get 9 total.. 6 to replace the ones they sent and 3 more for the cat... I'm about to go to Home Depot now and get something to get the bottom bolt off the front heat shield, as it was too small of place between the heat shield and radiator fan for my socket to fit. Any recommendations? I have a basic socket set with all the size ones I will need and a few different sized extensions. Also have a Dremel if I can't get the bolts off but I've sprayed them a few times with PB Blaster already.
Your best bet is probably a smaller socket wrench. And if you haven't done it yet, spray ALL of the bolts now before you start working. And every so often go back and spray everything again. It may take many, many sprays before they start to come loose. A breaker bar will also come in handy for the cat bolts. Just in case you can't get them off, do you have a drill and some good (titanium) bits to drill them out?
No He Can't
I'm gonna try and do this tomorrow after work. I still gotta pick up a few things from Home Depot and Wal-Mart, though. I should probably go ahead and get the Dremel battery charging for the cat bolts, because I went down there the other day and they wouldn't budge at all.
When I jack up the car, the stock jack only lets me go up to the first notch on my jack stands, so there isn't very much room for me to work. Also, they won't fit on the notches where I jack up the car when the jack is there because there isn't enough room so I am putting the jack stands on the frame.
Am I supposed to be jacking from somewhere else so I can get the jack stands on the notches right behind the front wheels or is there some other trick to getting the car higher with the stock jack?
There is a jacking point under the front bumper. Lift it up from there and then place the jack stands under both of the side jacking points. I hope this works for you, my buddy has a hydraulic jack so it was a lot easier than using the stock jack. If you can get one, I think they run like $20 at an automotive store, and believe me it will make your work a lot easier. Also, I don't know how tall your jack stands are compared to my buddy's, but we also left it at the bottom notch. There was just enough room to work under the car to get some good leverage (which you will especially need for the cat bolts). Have you been soaking all of the bolts the past couple of days?
Originally Posted by ryebreadisme
I think everyone has had tons of trouble with the cat bolts except me. That was the easy part. For me the hardest part was the rear manifold. That thing was nasty.
No He Can't
Well, I got it all done last night.
After going around to some places in town, I decided it was too much and to try this myself (got quotes from $150-300). I got the floor jack from Wal-Mart for $20 and went at it. I wish my internet would've been working so I could've seen the jack point because I lifted it up from another point and bent something pretty bad. But, thanks for the future reference.
All the bolts were very easy to get off. I highly recommend spraying the bolts with PB Blaster (or something similar) on all the bolts every night for about a week before you start (after the car cools; I sprayed it on cat bolts when they were still hot and it started smoking
). I did this and the bolts came off really easy and they looked pretty rusty (I have almost 140K miles). I also recommend getting the crush washers for each side of the manifold to b pipe bolts to help tighten everything down. You don't have to have someone on the other side holding the bolts while you tighten.
The whole install took me about 6 hours, but I also went to the store to get an adjustable wrench for the O2 sensor (the biggest one I had was 19mm) and had to wait for my roommate to get home to help with lining everything up at the end. If I had his help the whole time and had that wrench, I could've done it in about 3.5-4 hours. The hardest part for me was finally hooking the b pipe to the manifolds and actually getting every thing to line up.
Thanks for all the advice, everyone. This was actually really easy with all the instructions on here.
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
![what](https://acurazine.com/forums/images/smilies/what.gif)
I'm glad everything went well for you! My biggest mistake was not spraying the bolts ahead of time, we only started spraying them the day of the install, so it was a lot harder. What got bent when you were jacking it up? Hopefully it's nothing too important. How do you like the new power? Do you get that whooshing sound? How about any resonance? Remember to re-tighten all the bolts after a couple of weeks.
No He Can't
Yea I am going to tighten everything back after a week. I can feel the power a little bit, but I think the ECU just needs to get used to it for me a feel even more of it. I don't really have any resonance, but I don't know what it sounds like and what to listen for. I guess it kind of has a whooshing sound, but it sounds good to me.
I tried to jack it up from what I think is the frame and it didn't really get bent too bad, it just has an indentation from where the thing lifts it up with a jack like this
I can post some pics from under the car to show you what I am talking about if you would like, and maybe get some more input as to what I bent and what could happen from doing this.
![](http://www.cnjacks.com/images/floor_jack_1.gif)
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
