Wow, white lithium grease and coil isolators > *
Received 1,080 Likes
So I've been trying to figure out how loud I have to turn my radio up to get rid of the clunking and creaking sound coming from my suspension. Well I turned it to 11 and finally gave up.
Climbed under the car the other night and removed my Comptech sway bar bushings and loaded them up with white lithium gease.
Went to Acura and purchased two coil isolators from the MDX, cut them into 2-3" pieces and wrapped the springs on my coilovers with them.
Got in the car and went for a drive. I can't tell you how happy I am now. No clunking or squeaking whatsoever.
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Reminds me not to buy comptech suspension parts ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
Good fix!
Good fix!
Good fix!
Good fix!
Actually the sway bars are great. It's just that the bushings that hold it to the frame need an occasional grease.
The squeaking is from my TeinSS.
so you kinda made a coil sleeve right................do you know what the part # for the coil isolator is? I have Tien SS-p and the clunking and creaking is driving me crazy also,I lived with it for like 6 months already.........please help
I can go look but if you call the parts department tell them it's the coil isolator for the MDX. They will know what I'm talking about.
Hey NSXNext ... thanks for the tips ... I'm starting to hear the squeaking too ...
Of course, it goes away after it rains / snows ... haha.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Yeah, my rear bushings were frozen onto the sway bar from lack of lube. Took me a minute or two to peel them off. I guess the winter salt barrage didn't help.
it's been about a week and they still sound great. No clunking or squeaking.
a little trick i learned is to apply some anti seize compound on the inside of the bushing of the sways to help prevent squeaks and such.
CT needs to get their act together.
i posted a thread about the energy greaseable bushings, you should try them, their awesome.
https://acurazine.com/forums/showthread.php?t=179363
Yeah I read it on the 3rd gen forum a while ago, but I figure it only took me about 10 minutes to remove and regrease the bushings. I can't see needing a grease gun for anything other than that so I'll stick with my method.
Cool idea though.
hey, what does the squeaking sound like from the Ct sways? ive had a nice little squeak for quite some time now, and i dont know wtf it is. if i get under the car and pull on the sway, will i hear it? also, can i wrap the bars with teflon tape, and than grease the bushings? TIA
The squeaking was metal to metal from the coilovers.
I had a clunking sound coming from the sways. It sounded like something was loose, which in reality was the exact opposite of what was really happening.
my squeaking came back,I know I installed the isolators correctly cause the noise was gone for a while,It is worse when the weather is cold.My car sounds like a taxi cab with F-upped suspension.I have Tien SS-Pillow mount could this have something to do with it?...........how are your Isolators holding up NSXNEXT??
Mine are still fine. I'm get the clunking sound in the rear from the sway bars when it's cold. I think I might need to regrease them.
Did you glue the coil isolators onto the coils? Are they still there?
nsxnext - if you get the greaseable ones and the $15 greasegun, it would take you 5 mins max to grease all 4 bushings. =P hehe, just kidding, but actually i need to do that coil isolator, my car creaks all the time when its cold w/ the TEIN SS.
Going to PepBoys at lunch today.
Recently turned 18
Going to PepBoys at lunch today. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Recently turned 18
Did they have the fronts? Or did you not want these? I went to Autozone right after and they had a VERY similar looking grease gun for 10 bucks. Going to look closer maybe save $5.
fyi, i believe they only make 1 size in the 22mm greaseable bushing, but there are two diff sizes for the front 27mm. the one i got was better for me, but i'm in a CL, i dont know if it's different. mainly bc the bracket needs to sit in a groove, its not entirely flat on the front. so the long bracket would have been even harder to fit in there. but you guys might be able to get away with it.
also i picked up the 22mm ones at pepboys for 20+tax. but i couldnt find the 27mm anywhere so i sucked it up and ordered from summit. i got my greasegun at home depot, i think it was 15$ and it came with 1 tube of lithium grease. pepboys now sells them cheap too.
Recently turned 18
Damn Clean! Why didn't you say so before? Hahaha. I was almost bitching these people out for not having the 5162 (front). And coincidentally, I looked it up on Summit too. Was trying to figure out what shipping would be since it's 30% cheaper to begin with, but you have to fill out damn near all your info Beforehand. So...looks like I'll be sucking it up too!
Recently turned 18
Called a couple places and they're asking for either the Tech Service Bulletin # or the part #. I'm on hold with Tischer though. They're usually damn good from what I've heard. Follow along as I try to hunt down the rarely seen MDX spring coil isolators!
side note: I'm telling them it's an '05 if that makes any difference.
Recently turned 18
No luck with local dealers. Can't come thru as usual. I played the run around game over the internet too. Did a google search, ended up on a MDX forum, which oddly enough after some research guess where I ended up linked to from there?.....Right back HERE on AZ...hahahaha. Anyway, there is a TSB listing that goes back to at least 2000 (where I started my search) up to 2006. I did a search there and came up empty from 2000 to mid 2003. If anyone finds the TSB # or part # for these coil isolators PLEASE post this up. I have my buddies down in Atlanta researching it also, I hope they come through and I promised a little bit of added business if they did (hint hint).
NSXNEXT, if you wouldn't mind retracking your source for this and seeing if you can find the info I'd personally be appreciative. I also thought to ask you this, if you could somehow purchase more I'd be willing to pay for at least 2 complete sets, as long as the cost wasn't outrageous. Let me know how you can help. Thanks again.
...The hunt continues!
they only cost like 5$ a piece,you should only need 2.Then you need a weatherstrip adheasive to apply them to the coil(after cutting one up into 4 even pieces). Good Luck hope it works for you...........I now believe my clunking is coming from the plastic dust cover as the coil bottoms out,it contacts it causing an accordian like action which in turn make this "noise".
