Went to drag strip today :annoyed:
13.2@ 107 on Street tires
Went to the drag strip here in town and was very dissapointed in the TL-S. With Comptech Icebox and catback exhaust the best out of 10 runs in the 1/4 mile was 14.9..to me the TL should have run better than this...are these results right for the TL-S?
The system was not in...my car is an auto and my best reaction time was .658 on a .50 being the best possible. My car is an auto so there isnt much driver error. The track was really slow considering i chirped second with an auto..ive got video.. but here are my 3 best times...
.50 fastest possible launch
Reaction-- .813 -- .658-- .877--
60'-- 2.328-- 2.355-- 2.323--
330' -- 6.390-- 6.429 -- 6.429--
1/8 mile -- 9.645-- 9.697 -- 9.711--
1/8(mph)-- 75.59-- 75.24 -- 74.08--
1/4 -- 14.842 -- 14.915 -- 14.955--
1/4(mph)-- 95.06-- 94.65-- 94.15--
every race..ws6..z28..GT...i beat them all 60'..every race with stock wheels and BFG G-Force KDW. Burn out b4 each race..lowered pressure down to 20 lbs.. Still spun first gear with a lot of wheel hop
Originally Posted by Phesto
try using the SS next time............start in 2 to get a better launch......maybe look into some Nitto's for better traction
Originally Posted by PenancE
beat me to it lol....he must drive like my grandma
Originally Posted by type-s09
i tried all of it...ss...manually from 1 to d4...and regular d5...start out in 2? wouldnt that kill my launch with no power?
I don't think the TL is known to be a 1/4 mile car. If you want to drag race it, you need to set it up for drag racing. Your times are probably not far off from the best that the car can do, in it's present set-up.
o yeah vsa was definatly off...so u are saying to have the car in nuetral n then rev then drop it into drive?
You don't want to do a neutral drop, talk about killing the tranny. Just foot on the brake, while in gear, step on the gas to get it revved up a little bit, I find 1500 rpm to be good.
Originally Posted by Trojanman750
damn i couldnt imagine droppin the gears on the TL.....it would probably just break in half and fall out of the car after that much abuse!
Honestly... for those 60' times those are decent times.
A 2.1 60' would have resulted in a mid-14 second pass.
And whomever said start in 2nd for a better launch must be high
ditto.
reaction time makes no diff for ur 1/4 mi time.
60ft is one the most important items to improve.
for every .10 u drop on the 60ft, u know off .2-3seconds on ur time.
try working on ur launch and do some wt reduction, nothing in trunk, jack and spare out,
less than 1/4 tank of gas, 1 gallon equals 7lbs, decrease front tire pressure to get more traction, turn off all accessories.
these are just some hints that i have learned.
just my 2 cents worth.
check your 0-60ft to be 2.2-2.3 sec.. as for your modification i think is time to put some headers and a pulley on your car.. catback will not give you much gain ..
for your starts.. torke brake between 1500-2000rpm .. check your tire pressure.. if you spin on start maybe try 25lb-30lb of pressure max.. between each run cool down the car for 20-30min , remove the plastic on the intake manifold and put an ice bag on ..
First of all I have not seen many TL-S's that stock that run much faster then 14.70 so your not to far off. As for running low tire pressure that would only slow you down and create drag. You are using street tires not slicks. Slicks work on high HP cars because they grow once they get moving to reduce drag while still maintaining traction. You will never set the world on fire with a TL-S at the dragstrip no matter what you do. You can however win alot of bracket races if you get those reaction times in the consistant .520 range and your cars ET within a few thousand every run. You have a huge advantage bracket racing with an automatic. They are much more consistant then alot of the faster stick shift cars. Most of them will be giving you a head start and if you cut a good light you will force alot of mistakes. I think you should stop trying to be fast and work on being good. You can be a track champion on a riding mower if your consistant.
One more thing. Skip the burnout. There is no need for it. All it does with cars like ours is adds heat to the motor. I would drive around the water box and stage the car. You might find that your car runs a little better stone cold. The above idea about icing down the car is great. It works. Make sure you use plastic ice blocks or an ice bag. This will keep water from gettong into your plugs when it melts.
last few post are pretty good . . and to add on the burn out, I by pass the water, but I do a quick little spin to clean up the tires . . .
one other item, what was the humidity . . if it was high that could have knocked you down a 10th or 2.
Ruf
Ruf
You Seem To Be Haveing The Same Problem Figureing Out While The 1/4 Mile Time
On Yur Tl-s Is So High, I Spent The Day At The Track Yesterday, And I Made Four Passes, And The Best Run Was A 15.6? I Just Dont See How The Specs On The Stock Tl-s Say 14.7, And My Stock Tl-s Runs A 15.6 Some One Please Give Me Some Sugestions On Why My Car Is Running So Slow, Because My Reaction Times Were Killer, I Won All Races, But The 1/4 Times Sucked
02-tl-s Nbp-stock
1st Race 99 Maxima V6-smoked It
2nd Race 03 Rx-8-beat It By Maybe 2 Cars
3rd Race 94 Supra- Won The Race Only Cause Of My Reaction Time- He Ran A 13.8
4th Race 06 Eclipse V6 6spd-i Won From The Reaction Time, He Ran A 14.9
I Need To Find A Way To Get Some Top End- Open For Sugestons
02-tl-s Nbp-stock
02-tl-s Nbp-stock
02-tl-s Nbp-stock
