Want new horn
Want new horn
I posted up a thread a little while back with no luck, anyone replace their stock wimpy horn with a louder sounding one? If so any links on where to get one that will fit my 2001 Tl will help. thanks!
The horn on my 95 Integra is wimpy. I want to put air horns on it. The kit comes with a relay and it is supposed to hook up to a push button switch and a 30 amp fuse. The horn fuse under the hood is 20 amp. Can I change it for a 30 amp because I want to use the horn as normal from the steering wheel buttons?
You use the stock horn signal to trigger the relay. From the battery you get your fused 30amp power wire to the power on the relay.
`Freeway Blaster` 115db horn at harbor freight tools or most parts stores for under 15 dollars,,they make a high and low tone units, as most cars come that way
I replaced the one in front of radiator with low tone
they work great on my bike too~ BAAAAAAAAH!!!!!! Stay in your own lane!!!
