variable intake manifold
Old Apr 4, 2009 | 03:09 AM
tiblanc_lebrun's Avatar
Hi, can someone tell me what is the rpm point that the variable intake open? I adjust mine at 3600 rpm Thanks
Old Apr 4, 2009 | 08:37 AM
fsttyms1's Avatar
You cant adjust the 2nd stage intake, its preset to 4k. If your talking about Vtec leave it where it was. There is NO gains to be had by lowering it.
Vtec rpm points TL-P 4400 rpm (4800 rpm on the Type-S) 99 is 3800
Old Apr 4, 2009 | 08:57 AM
Hi, YES I can change my intake point because I instal a intake manifold from a 2006 tl on my 2002 tl-p and for controlling that I make a controller with a rpm switch so yes I can And I lowered my vtec with my vafc2 at 4200 rpm and desengage to 4000rpm thanks
Old Apr 4, 2009 | 11:33 AM
gold2003tl (90)'s Avatar
2003 TL-p
any power gains?
Old Apr 4, 2009 | 12:56 PM
I dont have any pic of that and I never make a dyno test but I know that in the tl-s it have a varible intake manifold that move the torque band in the lower and higher rev and for the lowered vtec point help when i shift the 3rd gear the vtec doesn't go off
Old Apr 4, 2009 | 12:59 PM
I will take some pic of that when I will go out my car in 1 or 2 week (is in winter storage)
fsttyms1's Avatar
So why didnt you say that in the first place.
Old Apr 4, 2009 | 01:01 PM
Hein? I make a question what is the rpm point when the intake change in tthe tl-s....
Old Apr 4, 2009 | 01:55 PM
Just for your info fsttyms1 (so you will not tell me why ...) is some mod I have make on my car : 2002 tl-p, j32a3 camshaft, j32a3 upper/lower intake manifold (port polish),xspower headers, ur pulleys, j32a2 tb, vafc2 with plx wideband, port and polish j32a1 head with angle cut valve job, cai, 2.5 exhaust with magnaflow cat and magnaflow mufflers
Old Apr 4, 2009 | 03:37 PM
fsttyms1's Avatar
You said and i quote
You said nothing of all your mods above. If you had stated in your post you did that stuff and had a RPM switch it would have cleared things up. I said it wasnt possible because there isnt a way to adjust it in the stock form.
I also hope you have a E-Manage or something to tune your car to take advantage of what you have done.
Old Apr 4, 2009 | 09:01 PM
Edward'TLS's Avatar
6G TLX-S
Any dyno plot to support how useful they are ?
Old Apr 5, 2009 | 12:55 AM
iforyou's Avatar
You'll Never Walk Alone
He said in post#5 that he has never done a dyno test on his car.
Old Apr 5, 2009 | 11:43 PM
sinfulj32's Avatar
TIBLANC, the variable butterfly on the type s opens at 3800rpms stock. hope this helps.
i myself prefer it open full time on mine.
Old Apr 6, 2009 | 04:11 AM
Thanks sinfulj32 !
Old Apr 6, 2009 | 10:09 AM
fsttyms1's Avatar
Why? You dont gain any more for it being open all the time.
Old Apr 6, 2009 | 10:42 AM
phee's Avatar
I got the Shifts
^x2 and you lose low end torque
Old Apr 6, 2009 | 11:37 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
Tu viens de ou ????
Old Apr 6, 2009 | 12:53 PM
Hey ! quelquun qui parle le quebecois! humm de granby
Old Apr 6, 2009 | 04:39 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
Ta msn?
Old Apr 6, 2009 | 06:05 PM
Edward'TLS's Avatar
6G TLX-S
Should consider one so as to know if messing around with the intake manifold runners and the VTEC engage point will actually reduce or increase the engine performance.
Old Apr 7, 2009 | 03:34 AM
ouais jai msn. tu vien de quebec ou du quebec ? héhé
Old Apr 7, 2009 | 05:37 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
Becancour.
Add me: justin@mchip.ca
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
joflewbyu2
Oct 8, 2015 11:16 AM
