UR pulleys for 03tls
What are the best UR pulleys i can get at reasonable price for my 03 tl-s ? Also, will there be any HP gains or its only to help the engine rev'ing well
Toots420 (06-20-2012)
Former Sponsor
We offer the UR crank pulley.
http://store.excelerateperformance.c.../i-291888.aspx
Or the pulley set.
http://store.excelerateperformance.c.../i-291889.aspx
Or the pulley set.
Or the pulley set.
Or the pulley set.
In the pictures of the stock pulley alone and the set of pulleys the crank pulleys are different. If I order the complete set do I get the same crank pulley that I'd get ordering it alone? Also does weight reduction of the p/s and alt pulleys make any change or is it just for making it all matching and pretty?
You can change out to the lightweight stock size pulleys and everything will stay the same as far as electrical output. The only pulley that comes under driven is the crank the rest are stock size. The gains all come from weight loss from removing very heavy pulleys and replacing with lightweight aluminum one. The rotational weight loss gives you the hp gains plus you're faster gettin to vtec range.
Former Sponsor
You get what you pay for. These are high quality lightweight pulleys that are CNC machined and 0 gram balanced.
The picture of the crank pulley alone is the most recent version of the crank pulley. You would get that one. The accessory pulleys add 1 hp each.
This is a stock diameter system so it will drive the alternator the same as the original pulleys.
mrkingstonvi
02-22-2016 01:53 PM
